メインコンテンツにスキップ
モデル番号はA1238/80、120、160GBハードドライブ/ブラックもしくはシルバーメタルフロント
904回答 すべてを表示
New Battery, won't charge up
Hi ! I have recently bought a new battery for my iPod, because the last one was starting to have a short duration of use. But the problem is that the new battery won't charge up : the battery logo show that it's fully loaded after 1 minute, and the it drains after 1 minute too, and that's only when I plug the iPod to the sector, otherwise the sreen keeps flashing with le Apple logo. If I put back the older battery, everything works, but I don't wanna do this. Someone help ? Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
dustytill, if it works with the old battery, but not the new one, exchange the battery. It sounds like you have a gotten a bad battery. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
13 件のコメント:
Hi. Are you sure of this ? Cause I don't wanna buy another one if it doesn't work again...Thanks
さんによる
You did say that the old battery works, but not the new one. To me that definitely means that it is your battery. Anything else is just a guess, you got to find a place to start....
さんによる
I have to specify that my older battery was 580 mAh one, and the newer is a 850 mAh for a longer battery life. Does that make a difference ?
さんによる
the mAh won't make a difference for as long as they are physically the same. Make sure they are the same thickness.
さんによる
No they aren't the same thickness, but why does it matter ?
さんによる
8件以上のコメントを表示
コメントを追加
回答を追加する
dustytill さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 11
今までの合計 1,731
