メインコンテンツにスキップ
The Asus Zenbook UX31A is a laptop released in June of 2012. It is a member of Asus's Ultrabook line. It features a 3rd generation Intel Core I7 processor and a full HD IPS Display.
36回答 すべてを表示
Volume buttons fn f11 won't work (asus zenbook ux31a)
So I have been researching everywhere and I did come upon the ifixit link with the step-by-step guide on how to "lock in the connector." However, even after doing that and taping it down with better tape, my volume button STILL does not work. Anybody else experience this? If so, what did you do to resolve the issue? The same works for when I try "fn" + f10/f11/f12 and I often get a delayed response for the "fn" + f5/f6.
Help please? Thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
6 件のコメント
I have a similar issue. When I hit F12 (the volume control) in an open browser, I get a window at the bottom that shows the page code. None of the volume control buttons work, and only some of the other function-buttons seems to have any affect. I'd love an answer to this. You don't pay $1500 for a computer that doesn't work. This is why people buy Macs. And why I'm starting to wish I did.
さんによる
YES! that happens to me too and the F10 won't work either. Is there any way to fix this?
さんによる
you have to press Fn key (left bottom of keyboard) and at the same time top keys whichever you want F5, F6 for brightness or F11 or F12 for audio volume down and up, respectivelhy
さんによる
Thank you for that! That's easy :)
さんによる
Is there a way to change it so you don't have to use the fn key to press those buttons?
さんによる
1以上のコメントを表示
コメントを追加
3件の回答
選択されたソリューション
You should check to confirm that the ATKACPI driver is installed along with any other hotkey utilities. The Asus support website has downloads for these items depending on your operating system. Here is the url: http://support.asus.com/download.aspx?SL...
At the top of the Downloads tab there is a drop-down to select your OS. The download you need is located in Utilities and it called; ATKACPI driver and hotkey-related utilities.
I hope this helps!
-TV
このアンサーは役に立ちましたか?
スコア 8
7 件のコメント:
oh my goodness it worked. thank you so so so much!!!!
さんによる
I would like to say YOU ARE AWESOME! IT WORKSSSSSSSS
さんによる
Really appreciate your help, thanks a lot bud!
さんによる
I have the same problem. But the file you recommend was allready installed on my computer. The problem remains. Any alternative solutions?
さんによる
It works! Very helpful! THANKS A LOT!
さんによる
2件以上のコメントを表示
コメントを追加
I've just started having this problem as well.
Function works with
f1, f5, f6, f7
Function DOES NOT work with
f2, f3, f4, f8, f9, f10, f11, f12
also my scrolling on the touch screen is intermittent, and my arrow keys don't always work. The laptop is 18 months old...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Have exactly the same problem with Asus K53SV...How did you solve the problem?
さんによる
コメントを追加
todd thank you ! this worked !!! Great.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Daphne さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 47,639
