メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
Earpiece speaker not working, all other sounds and speaker phone work
I need to know what would cause an iPhone 4s (verizon) earpiece speaker to not function at all. The only way for me to talk on the phone is with speaker phone. The problem started because my earpiece speaker was getting worse and worse, so I replaced it. After I replaced it I had NO SOUND AT ALL from earpiece. I reset network setting and then did a restore on the phone. Still nothing. Figuring I just got a bad part, and that some sound would be better than no sound at all, I put the old speaker back in. Still nothing. Another restore...still no. I took the phone back apart and cleaned all the connections and made sure everything was in its place and clean. When I turn up/down the volume it says "ringer"...so I know it's not stuck in "headphone" mode, but I cleaned the headphone jack too just in case. I am really good with electronics and have fixed many other iPhones with different issues and have a perfect record...except when it comes to my own iPhone. I just can't get this to work and have no idea what the problem could be. I would just like some opinions or suggestions...any advice I receive, if I choose to apply it to my phone I do so at my own risk. I know a lot of people won't give advice based on the fact that they don't want to be held liable. I really just need a clue as to what it might be so I can get this thing fixed. Any help that anyone could offer me would be GREATLY appreciated. I don't have any money to get the phone repaired...but, I will pay through paypal if the advice fixes my phone. I will give whatever I can to show my gratitude. It might only be $25, at the moment that's about all I have. But, if its advice that fixes my phone I will give what I have. I know it's a lot to ask for a cheap price, but it would really help me out. Thank you in advance to anyone who answers this.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
8件の回答
最も参考になった回答
Make sure you are seating the board back in the phone properly. I have seen iphones that people tried to fix at home and they did not seat the board in completely and the two prongs on the back of the speaker were not making sufficient contact.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Nothing worked until I used a skinner cotton bud/ cutip and cleaned out the headphone hole. I think dust was stuck inside and made it think it was in headphone mode rather than ringer mode.
Hope it helps.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Video call my voice can't reach opposite
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It sure sounds like you have double checked everything, you could have bought a bad ear speaker, also if you look at the ear speaker out of the phone under magnification there should have been a membrane that needed to be removed prior to installation that is really hard to see, it may be that it's blocking the sound, good luck !
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
av u gt ur answer i gt same problem
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
i have zen m68 phone but speaker not working plz give me sol,
さんによる
コメントを追加
My guess is you have it installed upside down the gold prongs that are pointing up must be at the top of the phone not pointing into flex cables
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
hellow tere i just have a phone whit this problem everiting is in god conection any sugestions??
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Samsung gt s5282 Other Sound Not Working
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
John さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 56,738
