Where is model number displayed on 2008 MacBook?
I need to replace a broken screen on my 2008 15" macbook pro.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The model number should be on the bottom of your MacBook Pro towards the back. It is printed on the aluminium close to the vents on the back. If it has worn off, which is a common occurrence, you can pull your battery out and get the serial number from the small grey strip that has computer info on it. You can then put the serial number into http://www.powerbookmedic.com/identify-m...
where it will tell you all you need to know about your computer.
Hope this Helps
このアンサーは役に立ちましたか?
Doesn't help me identify proper replacement parts.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,787
