How to fix my overheated xbox
help me im bored at my house
この質問は役に立ちましたか?
josh0987654322, avoid the towel trick. Yes, it may work for a bit, but there is a higher chance of damaging it further. To properly fix your xBox, either reflow the CPU/GPU and/or install the RROD kit. Hope this helps, good luck.
このアンサーは役に立ちましたか?
what i do when my xbox over heats is wrap a towel around it and put it near a fan for a good 1 hour. if this does not work then you can always put thermil paste on the cpu and gpu.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 736
