メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
締切られた回答
Why my iPhone has gray lines?
Hi,
I bought an iphone on ebay and there are horizontal gray lines on the screen as below.
But there is nothing on screenshot when I look on another screen.
Anyone knows this problem or has an idea of the solution?
Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Hi just want to check, you mean you have taken a screenshot and view it on another phone or on the same phone?, if you view the screenshot on another phone then it means that your lcd is faulty, provide us more info and maybe we can isolate and narrow dont the issue, hope that help, cheers!!
Update
Hi so based on your answer, it is the lcd that is faulty because when you view it o another phone there is no gray line, hence there is gray lines only on the phone that you are using, changing the lcd should solved the issue
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
When i view the screenshot on the same phone, Gray lines are there. But nothing on another phone. You say that LCD is faulty but lines are not always at the same place.
Thank you
さんによる
コメントを追加
The LCD could be a cheap £5.00 replacement part bought off eBay. These displays do work but can have faults, like uneven lighting around the screen and dead pixels. The display could be a cheap one.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Ok thank you. Can you give me some link to the part that you suggest?
さんによる
If you are in the USA, you could buy a display from iFixit. iPhone 4 (GSM/AT&T) Screen
さんによる
Ok thank you
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,928
