How do I upgrade my memory
Hi, i have just bought this laptop ibook g4 and i have realized it only has Mac OS X 10.5 (leopard) and the memory on it is only 1GB so i was wondering if it was possible to upgrade my memory?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The 1.33ghz iBook G4 has one memory slot, capable of holding up to a 1GB RAM chip. You can access this slot by pulling down on the tabs on the right of the esc key and to the left of the eject key, and then pulling up. If the keyboard doesn't pop up, turn the slit next to the num lock key 180 degrees. Once you pull up on the keyboard, set it on the palm rest area upside down and follow the instructions printed on the metal. (Remove the four screws).
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 222
