メインコンテンツにスキップ
モデル番号 A1367/ 8, 16, 32 もしくは64 GB容量
915回答 すべてを表示
締切られた回答
Power button isn't working after repair
I recently asked a question about repairing my iPod, because the home button wasn't working, and somebody gave me an answer with a guide on how to do it. I followed the instructions,and decided that before permanently putting it back together, I would put it together without the adhesive strips to make sure everything was working properly. The first couple of times, it came up with a white screen, but then it turned on, and worked fine. We went to put the adhesive strips on, and the cable on the top had come unclipped. We have tried snapping it back into place multiple times, but even when it appears to be in place, the iPod won't turn on. If anybody knows what might be the problem, I would greatly appreciate some help. Thank you.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
May be the power btn cable is damaged
iPod touch (4th Gen) Volume/Power Cable
iPod touch (4th Gen) Volume/Power Cableの画像
製品
$14.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 826
