メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
締切られた回答
No service/searching - poor signal on iPhone.
I got my iPhone 4 about two years ago, and got the screen and backglass changed from black to white about six months ago.
I dropped my phone while it was white but the signal started to disappear, but worked again when i restored it in iTunes.
I changed the glass back because i was going on exchange in the United States for a year, but after a while the service didnt work at all. I have tried everything, almost and i still dont know what is wrong with it!
Is it my antenna that is broke or what could it be?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
The options are, you need a new antenna, or make sure everything is grounded properly, check for a "blue coil" near where your antenna is and make sure its there if you don't see one you won't get service or it might be loose giving bad service. Another option is to hard reset it again. Also make sure the connector has a secure connection to the board, it might also be loose.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks!
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,573
