How much and were can I get my screen fix
my screen is cracked and when i turn it on it just show's a cracked black screen. I wanna know how much money it will take to fix it and were can i take it.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
stone, here is what I found about your DXG :"There are six screws on the outside of the camera. Three are underneath the rubber plugs. Remove the screws. Lift the cover off of the DXG. I start at the bottom and insert my fingernail in the gap and move it around the camera and carefully lift the top off. The hardest part is around the battery compartment. Try to keep the battery hindge on the bottom so that you do not have to worry about the door spring popping out. Don't panic if it does, cause it will still work. Once open you will see the battery compartment at the bottom and the LCD screen at the top. Remove the two screws at the bottom of the board just to the right of the push button and then right there were the HD/AV ports are. Next remove the 4 screws holding the LCD in and gently lift up the LCD. Underneath the LCD screen is the ribbon holder. You can either remove the screen completely or just lift it up. " from here. Hope this helps, good luck
このアンサーは役に立ちましたか?
I would encourage you to repair it yourself. Look on ebay for the parts.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 322
