iPhone4 is dead
my iphone4. sudenly dead and wont
tern on. i open it and pry out sleep butten
flex whtch include proximity sensor. conect to power for charge
it began to charge and turned on
i put flex to logic bord iphone freaze
and turned off. again no charging no
turning on. can power and proximity sensor or limbient light sensor
malfunction cause this or ther is another
problem?
thanks
Your question has me confused. You use a term "power flex" ? Is this the battery flex? When you pry it up, and connect to power it turns on, then when connect to logic board it turns off, if this is battery you are connecting and disconnecting. Then try a new battery.
Brad さんによる
i explained above i ment sleap awake flex.
tushmanluuu さんによる
battery voltage is about 4,when connect to usb it charge
and sync whit itunes consider that flex is
not connected(what you ment flex not changed)
tushmanluuu さんによる
