will not boot with battery
I have changed the magsafe connector and still have the same problem. The macbook will not boot with the battery in the notebook nor will it charge the battery. I able to boot up if I take the battery out. The process is to disconnect the power adapter, press the power button and hold then connect the power adapter, release the power button and then press the power button again and the macbook boots up. Of course, if the macbook gets disconnected from the power adapter, then the macbook turns off and you will need to do the reboot process again. You can however shutdown/restart and reboot the macbook as long as the power adapter has not been disconnected.
any ideas on how to fix the problem so that I can use the macbook with the battery?
