What can I do to repair the fuel pump hot lead?
Fuel pump hot lead broke at top of tank. How can I repair this?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If it is just the wire that broken, you should be able to crimp a new connector on the end and remove the old broken one from the terminal of the fuel pump. It should just be tightened to the fuel pump via a nut. If it is closer to the pump, you may have broken that terminal and will have to replace the fuel pump.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 694
