メインコンテンツにスキップ
1.83、2.0、2.1、 2.16、2.2、または2.4 GHzのいずれかのCore 2 Duoプロセッサーを搭載したModel A1181
1203回答 すべてを表示
締切られた回答
upgrade logic board with early 2009
Hi,
I have a macbook 13 core 2 duo mid 2007 and i would to upgrade the logic board if it's possible. can I upgrade with a macbook 13 early 2009?
thank you
Update
I have this macbook mid 2007 with logic board to replace because it come in touch with a liquid. And I had thinking to instal another newest logic board so i can instal mountain lion.
I know that the processor is different, but if i replace the all logic board what problem i can have?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Unfortunately, they have different chipsets and processor speeds.
Do you need to replace the logic board? If so, you first need to find out whether you have an energy-star or non energy-star Macbook. It sounds like a small difference, but the logic boards have different form factors.
Were you just looking for an increase in performance? If so, there are easier and cheaper ways to improve your computer's performance.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You can check this other question for a similar answer:
Swap late 2008 Black MacBook logic board to Mid 2009 logic board?
Basically, it is possible, but if your model is the white one, it would be easier to look for a used Macbook on eBay with a broken screen and just swap your working screen over to the working body.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,130
