Replace internal NAND flash memory
Can we replace Internal NAND flash memory of Samsung galaxy tab 7 plus... P6200
If yes wer do i get a replacement chip from...
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Faiz t, one can replace the IC's, if one have the right tools and the experience. It will involve a reball/resolder of the IC. Besides trying to find the proper chip, you also must find the proper stencil. You can only replace IC's that are of identical layout, otherwise it will not work on your logic board. This is most likely only a job for the most advances DIY'er, with all the right tools.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,513
