which ports are the eraphones and mic, nothing is marked
there are three holes in frront of computer , which one is mic and earphones?
Willy looking straight at the panel, left and center are audio jacks, right is mic jack. This model has dual audio jacks. Hope this helps, good luck.
このアンサーは役に立ちましたか?
Hi, two are headphones and one is microphone. The two near to you should be earphones and the one farthest to you should be microphone. Hope this helps. Write back with what happened. Good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 394
