メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
My iPhone works but the screen doesn't?
i've been told there may be something in the iphone that has caused the screen to stop working, the phone still works, i can take pictures and turn the volume on and off with the button on the side, but the screen wont display anything. Could it be something to do with the fixings on the inside and how much would it cost to get spare parts?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 13
コメントを追加
5件の回答
ベストアンサー
Just press home and power button for 20 seconds then Apple icon will appear and after 2 mins screen will come back on
Update
Well the answer is there for any future problems someone may have just hope it helps
このアンサーは役に立ちましたか?
スコア 14
12 件のコメント:
Hi Steven was this just after a repair that it happened?
さんによる
OMG I loove you!! this actually worked! I was about to cry
God bless you
さんによる
Very very happy!!!!!!!!! Thank you.
さんによる
This worked!!! Thank you!!!!!!!!!!!!
さんによる
this is so amzing thank you !!!!!!!
さんによる
7件以上のコメントを表示
コメントを追加
I would first try and reseat the connectors for the LCD and Digitizer. If they popped loose or have any corrosion sometimes that will be an easy fix. Unplug the battery, Remove the plate holding them down and reseat. Check for corrosion or burnt or damaged pins while your in there. But unless its gotten wet, you should be okay. Once you plug them back in, plug the battery back in and see if it kicks on.
If it does, close it back up and your ready to rock and roll.
If it doesn't, you may have a bad LCD or Damage to the mainboard.
Also, if it kicks on with the apple logo but then the back light shuts off a split second later, that's usually the indicator of a bad LCD. Replacing the front screen assembly should resolve this.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
You tried a hard reset or restore? Do you see any shadows of your screen when you angle the display toward the light? It is possible that the display assembly may need to be replaced, due to a malfunctioning LCD. It is possible that the ribbon cables or connectors are corroded, or loose. It is possible that your backlight IC/coil are malfunctioning. There are plenty of possibilities. The cost for spare parts is depending on your location.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
salam...
it seems like an lcd problem... you will have to replace the display assembly to know for sure. I hope its not the motherboard.
Malik.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Make sure that lcd flex cable is fitted properly in the logic board.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sarah さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 15
今までの合計 46,188
