Does not power on. dead
This iMac wont turn on. No start up sound, no video, no fan, totally dead.
The LEDs on the logic board don't show any light.
I guess is the power Supply, but before buying a new one, I would like to test it. Is there any way to do it?
Thank you
この質問は役に立ちましたか?
4 件のコメント
Double check your line cord first. Otherwise no real way without a DVM to test the voltages. What happened with it? did it work and then stop?
Dan さんによる
LIne cord is ok. iMac was working ok and suddenly stops. Is a DVM a Multimeter?
Flavio さんによる
Yes, a multimeter will work (D - Digital, V - Volt, M - Meter)
Dan さんによる
NOw the big question since I use the DVM only to test batteries, do you know how to use to test this power supply? Or if you know is there any web site with pictures? Thank you very much
Flavio さんによる
