It won't shut down!
This is a weird one, when I tell it to shut down, it restarts. Anyone know why?!?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
See if it happens in Safe Mode:
To start up into Safe Mode (to Safe Boot), do this:
Be sure the computer is shut down.
Press the power button.
Immediately after you hear the startup tone, hold the Shift key. The Shift key should be held as soon as possible after the startup tone but not before.
Release the Shift key when you see the gray Apple icon and the progress indicator (looks like a spinning gear).
このアンサーは役に立ちましたか?
Here's Apple's discussion of the problem, you might want to subscribe to this: http://discussions.apple.com/thread.jspa...
Like I said above, I tried everything listed in that post accept the re-loading the OS...
How exactly do you tell it to shut down? To make sure it shuts down hold the power button until it turns on. It should not turn back on.
このアンサーは役に立ちましたか?
Try clicking on apple, software update.....the problem may be due to software, and hopefully not hardware.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 5,399
5 件のコメント
Apple menu...shut down...it restarts...it's supposed to shut down not restart. The only way I can get it to turn off is if I hold down the power button. Is this just the way the laptop works? If so I feel stupid...
Dov さんによる
What happens when you hold it down? Keep it held down for a while. You may have to do a power manger reset.
rab777hp さんによる
Like I said, if I hold down the power button it works, it shuts down. It doesn't however shut down when I tell it to from the apple menu. All updates are current.
Dov さんによる
Try resetting the smc.
rab777hp さんによる
The only thing I haven't tried out of all these suggestions is re-loading OS software, but nothing has worked so far. Another thing I noticed when I plugged in it's charger, it turns on...
Dov さんによる
