メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
Camera shutter will not open.
Ok so after replacing the front and back glass covers and replacing the camera I have been unable to use the camera app as the virtual shutter will not open.
I have tried covering the camera's, cancelling the app in the background run bar, soft and hard reset, settings>general>restrictions disable-reset-enable camera and all possible combinations of the above methods with the original camera (that worked before case replacement but was dirty) and and the new replacement camera.
Reading further about damaged jumper points on the logic board ( http://www.gsmindia.in/forum/apple-iphon... ), I have opened the device and inspected the logic board. Both sets of points seem to be intact for front and back cameras. I then checked for continuity in the jump points from the first picture (points near the front camera), and then the points from the second picture (near the rear camera) with a multimeter. The first set seem fine however the second set gave a high impedance (~100Ohm) in both directions. Should I remove the connector at the second point set and jump it with a solder bridge? Is there anything I'm missing?
Front camera points.
http://www.technicalnet.ch/iphone/Frontc...
Rear camera points.
http://s9.mojalbum.com/15043899_16472183...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
As long as both resistors are still intact on the logic board, it's probably going to be either one of the cameras. Will the shutter open if you open the camera app through messages?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I think it's a bad idea. The logic board that you are seeing on these images are water damaged boards. So the values are maybe not good.
In this case I think the problem comes from Camera flex, maybe they're cut anywhere (micro-cuts). For my part, you have to change the camera and make cross test.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
iam unable to open my camera after all tries is there any hard ware problem in my iphone 4 16 gb
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Josh さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 4,207
