メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2189回答 すべてを表示
iPhone fell from 1 foot, doesn't work anymore.
Hello everyone!
My iPhone fell from about 1 foot, the display is black, like it has been turned off. Since then the iPhone became very hot, but has been cooled down now..
I tried to turn on the phone: nothing happens
Held homebutton and powerbutton: nothing happens
Plugged into a computer: nothing happens.
I hope it's something with a display-connector that isn't connected anymore, but would that declare the intense heat it produced since the fall?
That comes to my second thought, that there can be some damage to the motherboard.
Does anyone else have any ideas?
I would very much appreciate it!!!
Kind Regards,
Gertjan
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
最も参考になった回答
I'm not sure, because I can't see your phone.
Try to unplug your display data cable and plug it back properly.
Here the guide for you :
iPhone 4S スクリーンの交換
Reboot your phone.
If it doesn't work, then you have to change it.
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
Finister, something important to tell is, that he keeps rebooting, if I plug in the phone. I keep on hearing the boot sound, but nothing happens on the display.
I can see him on iTunes, but i can't restore..
I tried entering, fixing and exit recovery, but still no success.
On iTunes a message pops up, that the device isn't 'legible'.
さんによる
Doyou see cracks on your screen? Or white or colors lignes on your screen?
さんによる
Finister, no cracks, no white/colored lignes :(
Can it be something with the logic board? However, my Ifixit Pro Tech kit got delivered today, and now the pentalobe bit is damaged so i can't open up the iPhone... Now it's waiting for the single pentalobe bit to arrive.
But already a big thanks for your info and cooperation!
さんによる
I don't think so Gertjan De Mulder, in worst case I think you have to change your display assembly. There are very few chance for the motherboard to be affected, your iPhone fell only from 1 feet high.
さんによる
Finister, ok, thanks for all the info!
I'll try to fix that when my new pentalobe bit arrives, but first my other iPhone where i accidently poked off a capacitor from, i guess, the logic board. -.-'
さんによる
1以上のコメントを表示
コメントを追加
Same thing to my phone
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Gertjan De Mulder さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,027
