メインコンテンツにスキップ
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1502回答 すべてを表示
締切られた回答
Replaced battery, no charge, no reception, no wifi
So I just replaced my dying battery with a new one only to notice it wouldn't keep a charge (works only when connected to power outlet and shuts down when disconnected).
There's no service or wifi as well.
I double checked and tested all the connections and when I replace the new battery with my old one (which still has some juice left) everything works fine.
So I'm quite sure this isn't a connection problem.
But what is it? Is it the new battery not working correctly?
I was expecting this to be easier and more troublefree than it is now.
Thank you for your help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Have you found out anything else? Did you resolve your issue?
I just replaced the battery in a 3gs ... most cautiously without doing any visible damage under magnification.
Fully assembled:
- not charging
- doesn't respond to power button
- no wifi???
Redid all the steps. Same.
Update
I'm still waiting on new exchange battery. Phone has been fine on original battery.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
To update.
I opened the phone back up for the third time, inspected everything under magnification (no damage, dust, ... whatsoever) and put the original battery back in.
- power button works
- wifi is on and usable
- it charges
So must have received a bum battery ?
Or a battery with some bum little circuit board on it?
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 21
今までの合計 628
