メインコンテンツにスキップ
MacBookファミリーは2006年5月に登場しました。Appleの人気ラップトップであったiBookから引き継がれました。
3783回答 すべてを表示
締切られた回答
Slow downloading the internet, sometimes freezes
Macbook 13" purchased June 2009
I have tried to get help but not one computer person I know uses or understands Apple products. I have had to do all my own fixes.
The house I live in has upgraded to U-Verse and every other computer is very fast but mine. I can only think to replace the radio receiver under the clutch cover next. Would that even help?
<Ok, that's the lcd converter. Not sure where the radio receiver is located....does the airport card go bad and make things slow but still work?>
I found that if I click on the icon with the "receiving lines"(can't remember what it's called right now) and move the cursor off and back on it does a search for internet and, frankly, sometimes that's the only way I can do anything on the internet at all but it's a pain to "baby" my computer along all the time.
It is next to impossible to watch movies on my laptop.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
There are lots of variables here other than the wireless network card in your computer. FWIW wireless networking is wireless networking... it's standardized. If you live by yourself and have just a few machines then UVERSE internet is great, but, if you actually have a multi-person network through UVERSE, good luck getting what you pay for.
I believe AT&T could be throttling their home internet service just like they throttled their smart-phone internet package. To be clear, this problem is not limited to APPLE machines. It's limited to ALL machines; PC's, laptops, wired connections, wireless connections, everything.
Someone needs to access your router and change the wireless channel to 11 and also change the power setting to 10. This should make your signal strength stronger and stop the disconnects. It will also make a difference what part of the house you are in, compared to the other people.
FWIW if you want to watch movies on a laptop you should be using a wired connection it will be 10x faster than any wireless connection. Also set your buffer on the movie app (flash? DivX?) to be as large as possible.
If this answer was helpful please remember to return and mark it Accepted.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Terry - You could be facing a couple of different problems here.
First you need to know where the WiFi AP (access point) is located nearest to you physically in the building (you could have a few within the building) that is open for your use.
It's possible you could be accessing someone's private AP which by chance has access to the internet but thru a slower connection.
Once you know where it is physically you need to know its name and the settings to correctly setup your system to access it NOTE: this is no different for a PC or a Mac. If the distance is quite great you may want to ask the network folks (the one who manages your network at you house) if the AP could be placed closer to you.
OK, is the unit a 802.11n device? if so you should upgrade your AirPort software to support it if you can. See Apple TN AirPort Extreme Update 2007-004 It will update your Airport firmware to support 802.11n networks. Apple at one point sold this now its free. Make sure all other system updates have been applied as well as needed.
What do you see in the signal strength icon in the menu bar? It should be at least 2/3rd lit. If not you maye too far from the AP or the walls between you and the AP are blocking the signal. It's also possible the Antenna in your system needs repair to double check this take your system closer to the AP does the signal improve? If it does its more likely distance/interference issues.
Things which you can do to improve things on your side is to get an Airport Express Base Station (or other WiFi Router that can act as a WiFi repeater) and set it up as a repeater. Place the Express device at the best location within your unit to access the AP that connects you to the Internet. Once you set it up (very easy setup menu to follow) you can use your Mac to connect to the Express AP acting as a repeater which will connect to the other AP and on to the Internet! I would recommend setting up the Express with WPA or WPA2 so others don't connect to it (As the other connection side is not encrypted your info is still exposed! so don't use your credit cards or other personal info that you don't want others to see). If your U-Verse allows WPA or WPA2 connections by all means do set it up! that way your info will be protected over both WiFi nets (repeater AP and U-Verse AP). Just remember each networks WPA/WPA2 connection will use different passwords & encryption keys.
OK, you setup the repeater and the connection is still not very good (slow or drops out): Just like a building you can build a strong basement but the house on top is just rotten! networking is not much different. So far we worked on the physical WiFi connections and hopefully you have a good and stable WiFi setup as outlined above.
The house in our story here is the TCP/IP connection over the WiFi and wired network at the far end of your location (U-Verse to the Internet). Here is where your efforts can come to a bitter end.
You stated above others have good and fast connections so I'll say your TCP/IP connection should be OK, but... the AP your connected to may have higher traffic than other AP's in the building (if you have multiple AP's). You'll need to talk with the in house network folks to find out if they have too many connections on the AP. If they can see if they can move a few connections around to balance the loading or add another AP. If you still find the connection is slow you may need to talk with the U-verse folks to see if your link needs service or you need to upgrade to the next performance level.
Good Luck!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,020
