Black screen after replasement
Hi, help no backlight on my HTC one x after changed to new LCD/touch screen...
Tried to reboot and tried to add new rom but nothing..
Pleas help anyone?
There are multiple versions of the LCD. There are a few ways to tell (color of the flex, i believe is one). I think 2 are cross compatible, but the other one is specifically that version.
I would suggest comparing your old one to your new one, then contact seller of the screen.
このアンサーは役に立ちましたか?
Hi, i can not see any Big differense.. I have an picture if you can help me see? Email?
Hi again, my mistake, it is wrong Color on my new screen, switched back to this and all good! Tanks this was great;)
Where did you find your info? I have been struggling with this problem for almost two months and can not find the correct replacement. Are the different colors you're referring to on the backs of the end that connects to the mobo? Where do you find the different replacements?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 5,788
2 件のコメント
To just eliminate the possibility of this being a software issue - Did you test out your phone on a working rom after the repair? Or did you finish your repair then started flashing?
_Z_ さんによる
Hi, i test the orginal rom and the new. No luck. But i flashed after the repair.
Jan Ove Knudsen さんによる
