keeps turning itself off and on? help!
av had my phone almost a year and it just started turning itself off and on for no reason? av had it on charge and it still does it, any ideas on what it might be or a way to fix it??????????
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Ed Mourbey, the very first thing I would do , is to change the battery. It is most likely at the end of its lifecycle. Replace it and reevaluate. Also, clean the $$&# connector of any debris, check for broken, bend or corroded pins. You might even try a new cable. I am certain that a new battery will resolve this issue. Here is the guide and the battery is available right here. Hope this helps, good luck.
このアンサーは役に立ちましたか?
I would agree with oldturkey but also try resetting/factory restoring the phone in itunes. Could save you time & money
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 5,340
