touch screen not works
i have a HTC Desire HD poure water on my screen and now the phone works and lcd shows the background but touch screen not works what should i do?
この質問は役に立ちましたか?
評価: 1
srivandy255, make sure that you clean all the parts with high grade isopropyl alcohol. Check the connectors and cables for corrosion as well. If that does not change anything, replace your digitizer. It is possible that the circuitry of the digitizer is shortened out. Here is a guide, and here is a video on how to accomplish this. Hope this helps, good luck.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 5,670
