メインコンテンツにスキップ
Casio Exilim EX-Z850 is an 8.1 megapixel camera with 3x optical zoom. It can also record videos and has numerous "best shot" modes.
9回答 すべてを表示
締切られた回答
broken screen needs replacing
The screen on my camera broke when i accidentally knocked it and a kind of black ink covered it so I cant see what picture I am taking. Otherwise the camera is ok!! I know I can buy a replacement screen but how do i put it in the camera
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Lesley Saunders, here are the steps. Not a bad job :)
1. Remove the battery.
Removing the case
2. Remove six screws.
3. Remove the FPC while suspending the rear case assy, and then remove the rear case assy.
Note: Carefully remove the rear case assy as the FPC is connected.
Removing the LCD assy
4. Unsolder four lead wires.
5. Remove the screw.
6. Remove the connector, and then the LCD ASSY.
Note: The connector is under the LCD assy.
When removing the FPC, make sure to release the lock of the connector in advance.
Assembly Precautions:
Assemble the LCD assy after aligning it with the positioning pins.
Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 776
