メインコンテンツにスキップ
Released Apr 2008. 7MP camera with 3X Optical Zoom.
22回答 すべてを表示
Why my LCD screen stays blank.
My Kodak C713 LCD screen remains blank. The camera does record pictures (I've checked using a card reader). I have tried all buttons and functions and am using new AA batteries. What can I do?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
phil, if the camera functions without difficulty otherwise, I would think that the best start would be to replace the LCD. It is possible that the backlight on the LCD is no longer functioning.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
how do u replace the light
さんによる
Della Howard, what light?
さんによる
I have a similar problem, I can see the backlight turned on but the image on the screen is very low, when turned on it shows a little and as the seconds go by the image becomes progressively lower and lower. The camera seems to work fine with the other functions.
さんによる
@mrcroket same as in the original answer. This could be an LCD issue as well as a DC-DC board issue. Start with the easier fix which is the LCD and then re-evaluate.
さんによる
コメントを追加
回答を追加する
phil さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 814
