<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Whirlpool Washing Machine&quot;]]></title>
<link>https://jp.ifixit.com/Answers/Device/Whirlpool_Washing_Machine/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Whirlpool Washing Machine&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sat, 27 Jun 2026 19:10:05 -0700</pubDate>
<item>
<title><![CDATA[Whirlpool Washing Machine: Whirlpool lid lock bypass]]></title>
<description><![CDATA[<p>I have a Whirlpool wtw5000dw1  and I'm trying to bypass the lid lock by cutting the wires. They are res white and blue. Which two should I cut?</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_06_29_Num_2019" class="header">Update (06/29/2019)</h3></div>
<p>*red, white, and blue</p>
<p>⟐ Commented 6月 20, 2026 at 6:30 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/575981/Whirlpool+lid+lock+bypass</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/575981</guid>
<pubDate>Sat, 20 Jun 2026 06:30:10 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag or Whirlpool Centennial washer: Top loading wont do anything but hum I move the drum it stops then sta]]></title>
<description><![CDATA[<p><strong>Button doesnt light up ,no movement,grinding noise</strong></p>]]></description>
<link>https://jp.ifixit.com/Answers/View/958359/Top+loading+wont+do+anything+but+hum+I+move+the+drum+it+stops+then+sta</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/958359</guid>
<pubDate>Fri, 05 Jun 2026 14:08:20 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: My frigidaire top load washing machine won't continue any cycle.]]></title>
<description><![CDATA[<p>The lid locks and the water will start to fill but only for a couple of seconds then stops. The same with draining. It will start to spin but only for a few seconds. I can hear clicking sounds from the motor control unit but then it stops. I've replaced the lid lock assembly. Also, when I begin the cycle, the washing machine will not spin to sense the cycle.</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_02_19_Num_2020" class="header">Update (02/19/2020)</h3></div>
<p>Frigidaire Affinity FAHE1011MWO</p>
<p>⟐ Commented 5月 12, 2026 at 14:57 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/618350/My+frigidaire+top+load+washing+machine+won&#039;t+continue+any+cycle.</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/618350</guid>
<pubDate>Tue, 12 May 2026 14:57:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: F9E1 whirlpool washer won't drain FIXED]]></title>
<description><![CDATA[<p>UPDATE: NO POLARITY. CONNECT THE WIRES HOWEVER YOU WANT. Wtw5100hw0 wouldn't drain, so I checked the hose for clogs. Checked the plug for continuity and nothing. I found a break in the wire so I fixed that. Check continuity and nothing, I cut the connector off and both wires have continuity. Now the problem is I can't find the connector I cut off. I have female spade connectors on the wires but have no idea which wire goes to what terminal on the pump.</p>
<p>⟐ Edited by author 5月 03, 2026 at 15:19 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/952819/F9E1+whirlpool+washer+won&#039;t+drain+FIXED</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/952819</guid>
<pubDate>Sun, 03 May 2026 15:19:17 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Whirlpool 1cwtw4845ew1 toploader cold water valve solenoid?]]></title>
<description><![CDATA[<p>The above mentioned washer refuses to fill up on the cold water side randomly, basically you can hear an electric humming sound but no water enters. So I have already figured it must be the solenoid going bad (or am I wrong)? Hot water side works just fine. Did the manual check, and indeed cold water side throws an error. Question: I already found the whole inlet valve available, but I suppose just the cold water solenoid is not available for purchase? Or is there another fix I could use. The part (whole valve body with hot and cold water) is rather expensive, so if at all possible, would rather not purchase it right now.</p>
<p>⟐ Edited 5月 03, 2026 at 1:35 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/953084/Whirlpool+1cwtw4845ew1+toploader+cold+water+valve+solenoid</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/953084</guid>
<pubDate>Sun, 03 May 2026 01:35:49 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Clothes sopping wet at the end.]]></title>
<description><![CDATA[<p>2 year old Whirlpool wtw5000 top loader.</p>
<p>Washer washes, rinses and drains fine, water pumps out like crazy. It's spins. I'm not sure how it's supposed to spin compared to our old style washer. It spins stops , pumps some water, spins and stops pumps some water and then it's done. But there's still some water down below and clothes are sopping wet? The darn thing takes so long to do a load of clothes I've never really paid attention to what it does and when. So everything seems normal except the clothes are wet.</p>
<p>⟐ Commented 4月 29, 2026 at 19:19 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/387411/Clothes+sopping+wet+at+the+end.</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/387411</guid>
<pubDate>Wed, 29 Apr 2026 19:19:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Why F - 28 shows up on the display and door not opening]]></title>
<description><![CDATA[<p>Why F -28 flashing on the display and door not opening</p>
<p>⟐ Commented 4月 29, 2026 at 0:58 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/415954/Why+F+-+28+shows+up+on+the+display+and+door+not+opening</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/415954</guid>
<pubDate>Wed, 29 Apr 2026 00:58:16 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: an oL code comes up]]></title>
<description><![CDATA[<p>My Whirlpool Cabrio washer was just moved in.  It is an older one and works until it gets near the end… an oL code comes up and the clothes aren’t completely spun out…. I need suggestions…. Wondering if it can be related to the computer due to the move.</p>
<p>⟐ Edited 4月 28, 2026 at 9:26 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/952488/an+oL+code+comes+up</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/952488</guid>
<pubDate>Tue, 28 Apr 2026 09:26:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: I can't get the control lock off.]]></title>
<description><![CDATA[<p>I can't even find a picture of my washer when it comes to this matter. It says to press and hold the control lock button for 3 seconds, there is no button there it's just the light. This is a whirlpool duet front loading steam washer and the control lock light is on I've got to do laundry please help me please help me today</p>
<p>⟐ Commented 4月 28, 2026 at 9:23 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/809578/I+can&#039;t+get+the+control+lock+off.</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/809578</guid>
<pubDate>Tue, 28 Apr 2026 09:23:40 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag or Whirlpool Centennial washer: Leak when spin drying]]></title>
<description><![CDATA[<p>My washing machine will leak when spin drying</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/951115/Leak+when+spin+drying</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/951115</guid>
<pubDate>Sun, 19 Apr 2026 08:38:34 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Whirlpool 1cwtw4845ew1 toploader engaging lid lock non-stop]]></title>
<description><![CDATA[<p>Whirlpool washing machine 1cwtw4845ew1 was in the middle of the washing cycle when it started engaging and disengaging the lid lock randomly, and now it won't do anything else anymore. Tried reset as per a Youttube video, but the lid lock keeps on clicking non-stop when the machine is plugged in.</p>
<p>⟐ Commented 4月 18, 2026 at 10:22 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/907409/Whirlpool+1cwtw4845ew1+toploader+engaging+lid+lock+non-stop</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/907409</guid>
<pubDate>Sat, 18 Apr 2026 10:22:28 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag or Whirlpool Centennial washer: I need to know a component from the main board]]></title>
<description><![CDATA[<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/KAdUoqEGgoKDqphC.standard" width="104" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/KAdUoqEGgoKDqphC.full&quot;, '', 'width=1080,height=2340')" /></div>]]></description>
<link>https://jp.ifixit.com/Answers/View/948798/I+need+to+know+a+component+from+the+main+board</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/948798</guid>
<pubDate>Sun, 05 Apr 2026 14:28:22 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Why is my washer still not working after I replaced the lid switch cyc]]></title>
<description><![CDATA[<p>I replaced the lid switch on my whirlpool 2in 1 removable agitator washer due to a broken clip after replacing the washers an entire cycle threw no problem wen I went to start the nxt one it wouldn't work all the sudden I looked up and tried most every diagnostic entry and nothing has worked so far I need help</p>
<p>⟐ Commented 4月 04, 2026 at 21:37 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/948674/Why+is+my+washer+still+not+working+after+I+replaced+the+lid+switch+cyc</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/948674</guid>
<pubDate>Sat, 04 Apr 2026 21:37:23 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Machine makes Grinding/growling noise]]></title>
<description><![CDATA[<p>Machine makes noise at end of cycle.  I can still use machine after a reset but have to unplug it between washes.</p>
<p>⟐ Commented 3月 17, 2026 at 1:57 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/945355/Machine+makes+Grinding-growling+noise</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/945355</guid>
<pubDate>Tue, 17 Mar 2026 01:57:30 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Whirlpool front loading washer does not stop filling water during wash]]></title>
<description><![CDATA[<p>I have a Whirlpool Duet Steam front loading washer model WFW9550WL00.</p>
<p>Have an issue that started after the last wash cycle.</p>
<p>During the wash cycle with a full load the water does not stop filling and eventually water starts leaking out front door (drum is half full of water and rising).</p>
<p>I tired a wash cycle with an empty load and no leaks or overfilling of water.</p>
<p>I checked the pressure sensor hose and blew in the hose to check for clogs (no clogs). I have ordered a new pressure sensor (will be delivered in a few days).</p>
<p>Is there any other reason why the washer would overfill and not stop filling with water when clothes are in the machine compared to when it is empty during a wash cycle.</p>
<p>Thanks</p>
<p>⟐ Commented 3月 07, 2026 at 7:20 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/943274/Whirlpool+front+loading+washer+does+not+stop+filling+water+during+wash</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/943274</guid>
<pubDate>Sat, 07 Mar 2026 07:20:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: whirlpool washer , just keeps draining and when you move the basket it]]></title>
<description><![CDATA[<p>My whirlpool washer , just keeps draining and when you move the basket it stops for maybe a minute, then starts right back up , no stopping???</p>
<p>⟐ Commented 3月 06, 2026 at 23:53 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/943629/whirlpool+washer+,+just+keeps+draining+and+when+you+move+the+basket+it</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/943629</guid>
<pubDate>Fri, 06 Mar 2026 23:53:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Washer won't stop spinning at the end of rinse cycle.]]></title>
<description><![CDATA[<p>My Whirlpool Thin Twin washer (model number YLTE5243DQ1) works fine until it gets to the spin cycle at the end of the rinse (not the final spin) it spins up fine, but won't stop, it just sits spinning endlessly until you manually advance the timer to the next part of the cycle. The timer works fine for all other cycles and positions.</p>
<p>I checked the drain hose for clogs, it was full of water but I couldn't see an obvious blockage. The unit is in a small tight closet so I'm pulling it out tonight to get a better look at everything. Is it normal for the drain hose to have about a liter of residual water left in it after the drain cycle?</p>
<p>I'm really hoping this isn't a timer issue since the other positions in the timer seem to work fine.</p>
<p>Thanks!</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_03_01_Num_2016" class="header">Update (03/01/2016)</h3></div>
<p>Oh I should have clarified that it does stop spinning when the door is opened, but it will start up again once the door is closed. It's just the timer that won't advance when that particular spin cycle is running. It advances for all other parts of the cycle just fine.</p>
<p>⟐ Answered 3月 06, 2026 at 16:16 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/294186/Washer+won&#039;t+stop+spinning+at+the+end+of+rinse+cycle.</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/294186</guid>
<pubDate>Fri, 06 Mar 2026 16:16:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Whirlpool LSR8233EQ1 washer will not spin correctly]]></title>
<description><![CDATA[<p>Hello, I had my transmission break and it was slipping and making a banging noise on the spin cycle. So I ordered a new transmission. After replacing it now the washer agitates fine but then when the motor spins the opposite direction to make it do the spin cycle it will not spin until I open the lid for a second and close it. Then it spins fine. As long as it doesn’t switch to agitation it will continue to spin fine. They sent a replacement transmission and it does the same. Any ideas on what could be wrong?</p>
<p>⟐ Commented 3月 03, 2026 at 7:45 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/837689/Whirlpool+LSR8233EQ1+washer+will+not+spin+correctly</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/837689</guid>
<pubDate>Tue, 03 Mar 2026 07:45:09 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Motor noise after the cycle]]></title>
<description><![CDATA[<div class="large videoFrame videoBox_center" style="width:452px"><div class="videoBox"><video id="SgFgSEtDxYqQhTWQ" controls width="448"   height="252"   poster="https://guide-images.cdn.ifixit.com/igi/oPIq1Sy5sIsZNDXb.large" loop   >  <source src="https://documents.cdn.ifixit.com/igo/video/ifixit/SgFgSEtDxYqQhTWQ_MP4_720.mp4" type='video/mp4; codecs="avc1.4D4029, mp4a.40.2"' res="720" label="480p" /> </video></div></div>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_02_23_Num_26" class="header">Update (02/23/26)</h3></div>
<div class="large videoFrame videoBox_center" style="width:452px"><div class="videoBox"><video id="NtPtMOBRc2ScGaoJ" controls width="448"   height="252"   poster="https://guide-images.cdn.ifixit.com/igi/AmUfXatNDVV2wxGW.large" loop   >  <source src="https://documents.cdn.ifixit.com/igo/video/ifixit/NtPtMOBRc2ScGaoJ_MP4_720.mp4" type='video/mp4; codecs="avc1.4D4029, mp4a.40.2"' res="720" label="480p" /> </video></div></div>
<p>⟐ Commented 2月 26, 2026 at 9:05 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/941790/Motor+noise+after+the+cycle</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/941790</guid>
<pubDate>Thu, 26 Feb 2026 09:05:28 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Why is my washer roaring?]]></title>
<description><![CDATA[<p>Our Whirlpool top load washer (WTW5010LW0) is making a loud roaring noise when it spins. It has no other problems except for the loud roar on spin. It has a little bit of the noise when I manually spin the drum. It is around 3 or 4 years old</p>
<p>⟐ Answered 2月 12, 2026 at 14:53 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/939362/Why+is+my+washer+roaring</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/939362</guid>
<pubDate>Thu, 12 Feb 2026 14:53:54 -0700</pubDate>
</item>
</channel>
</rss>
