<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Retina MacBook 2017&quot;]]></title>
<link>https://jp.ifixit.com/Answers/Device/Retina_MacBook_2017?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Retina MacBook 2017&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Fri, 04 Sep 2026 16:24:38 -0700</pubDate>
<item>
<title><![CDATA[Retina MacBook 2017: MB 2017 won't turn on - how to diagnose before moving to logic board?]]></title>
<description><![CDATA[<p>This 2017 MacBook Retina 12 inch is dead. Different chargers and cables don't make a difference. Resetting SMC with the left ctrl + left option + left shift + power for 10 seconds doesn't work. Holding down the power button for 10 seconds doesn't work.</p>
<p>I even gently lifted the logic board from the internal battery connector, held it in place with plastic spludgers, plugged the MacBook into a charging brick, and tried the  key combinations above.</p>
<p>What else can I do before testing the logic board...which I  haven't found any guides to do at the moment.</p>
<p>Can I test the USB-C port with a multimeter to check for connectivity?</p>
<p>Any advice that helps me diagnose this would be great!</p>
<p>Edit: I've attached a photo of the board.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/cVpRboic1oMAKQbT.standard" width="169" height="225" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/cVpRboic1oMAKQbT.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/rI625nZvwPPTD2kN.standard" width="282" height="211" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/rI625nZvwPPTD2kN.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>⟐ Answered 8月 02, 2023 at 5:51 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/729392/MB+2017+won&#039;t+turn+on+-+how+to+diagnose+before+moving+to+logic+board</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/729392</guid>
<pubDate>Wed, 02 Aug 2023 05:51:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[Retina MacBook 2017: Only 1 second of backlight]]></title>
<description><![CDATA[<p>I've been trying to diagnose a problem with mid 2017 A1534, board 820-00687.</p>
<p>Doesn't turn on.</p>
<p>When trying to turn on, LCD backlight comes on for about one second, and nothing happens after that, also there is no image while that happens or after (when shining a light on LCD).</p>
<p>Negotiates and takes 20v properly from charger.</p>
<p>Gives a chime when connecting the charger.</p>
<p>I'm a complete novice in board level troubleshooting, so don't be surprised if I don't know something obvious. I did read up everything I could find.</p>
<p>So far I think I've narrowed it down to something around the L8410 inductor.</p>
<p>Schematic says that after the inductor voltage should be around 45v, while instead it's 8.6 exactly like before it.</p>
<p>I assume something should pulse the input into it to boost the voltage for the backlight, but there is no pulsing. Just stable DC.</p>
<p>Probably that &quot;something&quot; is U8401 which controls the Q8406 MOSFET which should be doing the pulsing.</p>
<p>Are there any preconditions to U8401 initiating the pulsing? Or should I assume that it's dead?</p>
<p>Edit: BKLT_EN_R coming from CPU to U8401 does go to 3.3v and stay there.</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_02_15_Num_2023" class="header">Update (02/15/2023)</h3></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/HsXsdIsKfF4kZn3a.standard" width="282" height="211" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/HsXsdIsKfF4kZn3a.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/1fWAggpIyaTgDKUG.standard" width="282" height="211" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/1fWAggpIyaTgDKUG.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>As for the differences, I'm using a brd file for 820-00244, so far the only difference I found was at the XW8401 slot, which shows a component in the file but not present on the board.</p>
<p>⟐ Answer accepted 5月 15, 2024 at 1:29 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/769123/Only+1+second+of+backlight</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/769123</guid>
<pubDate>Wed, 15 May 2024 01:29:21 -0700</pubDate>
</item>
<item>
<title><![CDATA[Retina MacBook 2017: Can individual keys be replaced?]]></title>
<description><![CDATA[<p>I have a few sticky keys on my 2017 MacBook. I think I have spilt something, I tried using compressed air and cleaned them with solution, but it hasn't worked. Is it possible to replace individual keys?</p>
<p>⟐ Commented 5月 10, 2023 at 17:38 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/431443/Can+individual+keys+be+replaced</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/431443</guid>
<pubDate>Wed, 10 May 2023 17:38:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[Retina MacBook 2017: Is deleted BootCamp partition recovery become possible macOS Sierra?]]></title>
<description><![CDATA[<p>I have accidentally deleted bootcamp partition on my Mac computer using disk utility because windows 8 has been damaged or corrupted while I try to resetting it. Note that I wasn't using bootcamp assistant to install windows 8. I managed to make my drive into a single partition but when I press alt/option on boot, I still can see the windows boot option and the data stored in it. How to repair my Mac hard drive so the windows boot option disappear?</p>
<p>Please tell me any solution on how to restore the BootCamp partition data back to my Mac hard drive and regain access to it?</p>
<p>⟐ Answer edited 10月 01, 2018 at 9:28 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/518414/Is+deleted+BootCamp+partition+recovery+become+possible+macOS+Sierra</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/518414</guid>
<pubDate>Mon, 01 Oct 2018 09:28:52 -0700</pubDate>
</item>
<item>
<title><![CDATA[Retina MacBook 2017: MacBook is taking power but is not turning on]]></title>
<description><![CDATA[<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/4nkd52efnbCHcxNX.standard" width="282" height="211" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/4nkd52efnbCHcxNX.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>I bought this MacBook knowing that it didn't turn on. Now I'm under the hood, the light next to the battery disconnect is lighting up, but still no boot. When I plug it into power without the battery connected, the light comes on, but still nothing. The area around the keyboard warms up like my working MacBook Pro when charging. The MacBook is taking power but is not turning on. I've checked the charge port (no physical damage), all the ribbon cables (also no damage), and still nothing. Could it be the actual power button? Idk what to check next.</p>
<p>⟐ Commented 9月 26, 2025 at 20:06 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/918868/MacBook+is+taking+power+but+is+not+turning+on</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/918868</guid>
<pubDate>Fri, 26 Sep 2025 20:06:53 -0700</pubDate>
</item>
<item>
<title><![CDATA[Retina MacBook 2017: MacBook 2017 parts for a MacBook 2016]]></title>
<description><![CDATA[<p>Hi all,</p>
<p>i own a 2016 MacBook and the system itself is going good. However the screen is showing some wear and the keyboard is starting to melt (to be expected). <br />i found a MacBook 2017 for parts (motherboard failure). <br />how feasible would a full transplant be? Moving the 2016 motherboard to the 2017 body (keeping the 2017 battery)</p>
<p>let me know what you think, thanks!</p>
<p>⟐ Answer accepted 11月 02, 2022 at 6:53 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/708826/MacBook+2017+parts+for+a+MacBook+2016</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/708826</guid>
<pubDate>Wed, 02 Nov 2022 06:53:17 -0700</pubDate>
</item>
<item>
<title><![CDATA[Retina MacBook 2017: Only The Base System is Available in Disk Utility (Recovery Mode)]]></title>
<description><![CDATA[<p>I have this issue that in recovery mode only the base system is available in show all devices within disk utility.... the owner of the unit said they 'reset' the unit for the new owner to install and setup to their own preferences.... unclear on what they did as they are no doubt without knowledge on how to correctly do this type of thing, but I guess they just deleted the whole SSD partition and now it is not found by the system.</p>
<p>I have reset SMC &amp; PRAM to no avail. Running first aid in disk utility finds nothing. There is only 1 USB-Type-C connector on the side so target mode isn't possible AFAIK. .. When I go to internet recovery it prompts to install Ventura but there no option to select any disk to install it on..... no option for erase in disk utility.....  <a href="https://iboysoft.com/questions/how-to-fix-macintosh-hd-not-showing-in-disk-utility-and-question-mark-folder-macbook-pro.html" rel="nofollow noopener noreferrer">This is what I have tried</a></p>
<p>Opt+Cmd+R - Disk utility shows only the base system 2.14 GB</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/OqlMKbCuRRoIChph.standard" width="282" height="160" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/OqlMKbCuRRoIChph.huge&quot;, '', 'width=1600,height=910')" /></div>
<p>Termianl just lists 16 disks no larger than a few KB to 6 MB</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/saqTjIEDwhKKFIMF.standard" width="218" height="225" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/saqTjIEDwhKKFIMF.huge&quot;, '', 'width=1162,height=1200')" /></div>
<p>Only 1 partition size is 3.22 GB</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/1IwNQkneN2eyHdqU.standard" width="282" height="132" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/1IwNQkneN2eyHdqU.huge&quot;, '', 'width=1600,height=749')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/GyWVTDqvRXFgRQnl.standard" width="282" height="158" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/GyWVTDqvRXFgRQnl.huge&quot;, '', 'width=1600,height=901')" /></div>
<p>Sorry for the poor images..... <strong>Please leave a comment until we can post a definitive working answer</strong> as I found a few posts online and there seems to be a fix for it but for me it didn't work and was unclear on if or how they did it.... I am sure there are many out there who had this same issue and would love to know how to fix this if possible....</p>
<p>I managed to boot externally and in the about this mac (Storage) it only shows the external drive size. Disk utility shows <strong>NOTHING</strong> internal. Apple diagnostics report no issues found. I cannot run the terminal command system_profiler SPSerialATADataType as command not found.</p>
<p>I guess it is increasingly looking like it had some sudden SSD Failure and the end of the road for this Mac. <a class="user-mention-link notranslate" href="/User/4379401/Jadon+Lyon">@jadonlyon</a> &amp; <a class="user-mention-link notranslate" href="/User/263105/oldturkey03">@oldturkey03</a> if they can shine some light for me.</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_09_14_Num_24" class="header">Update (09/14/24)</h3></div>
<p>SSD is dead and the unit shall be returned to the owner to bin sadly.</p>
<p>UPDATE: R7237 Resistor ? <a href="https://www.youtube.com/watch?v=iB5c3GezLxA">2017 Macbook 12&quot; A1534 NO SSD Repair</a></p>
<p>⟐ Commented 9月 19, 2024 at 4:30 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/869384/Only+The+Base+System+is+Available+in+Disk+Utility+(Recovery+Mode)</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/869384</guid>
<pubDate>Thu, 19 Sep 2024 04:30:46 -0700</pubDate>
</item>
<item>
<title><![CDATA[Retina MacBook 2017: Will an ultrasonic cleaner fix a liquid damaged keyboard/topcase?]]></title>
<description><![CDATA[<p>My 5 Gal Crest CP1800HT ultrasonic cleaner just arrived, and I'm excited to start shoving everything in it that I couldn't fix by hand. I have approximately 60 liquid damaged top cases, and I'm wondering if anyone's ever tried fixing them with an ultrasonic cleaner, and if you've had success?</p>
<div class="large videoFrame videoBox_center" style="width:452px"><div class="videoBox"><video id="iISVfXZh5jXrJRPB" controls width="448"   height="252"   poster="https://guide-images.cdn.ifixit.com/igi/uaABw41qDGxQF4oQ.large" loop   >  <source src="https://documents.cdn.ifixit.com/igo/video/ifixit/iISVfXZh5jXrJRPB_MP4_720.mp4" type='video/mp4; codecs="avc1.4D4029, mp4a.40.2"' res="720" label="480p" /> </video></div></div>
<p>⟐ Commented 5月 27, 2024 at 8:04 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/801286/Will+an+ultrasonic+cleaner+fix+a+liquid+damaged+keyboard-topcase</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/801286</guid>
<pubDate>Mon, 27 May 2024 08:04:46 -0700</pubDate>
</item>
<item>
<title><![CDATA[Retina MacBook 2017: MacBook is not charging, or booting up]]></title>
<description><![CDATA[<p>Hi All,</p>
<p>I have got many dead MacBooks 12” retina 2017, and obviously, they all have same issues with a burned USB-C port.  Anyone else facing this kind of issue?!?</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/pILJ2eptDS2yPEXV.standard" width="282" height="211" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/pILJ2eptDS2yPEXV.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/sSduOBvoXbbKXvyF.standard" width="169" height="225" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/sSduOBvoXbbKXvyF.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>⟐ Answered 1月 30, 2024 at 16:24 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/834447/MacBook+is+not+charging,+or+booting+up</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/834447</guid>
<pubDate>Tue, 30 Jan 2024 16:24:19 -0700</pubDate>
</item>
<item>
<title><![CDATA[Retina MacBook 2017: My USB-C connector charges but does not work when using a pheripherial]]></title>
<description><![CDATA[<p>Hi all.</p>
<p>My MacBook from 2017 (model 1534) has a single USB-C port. The port is used for charging and it works well. However, it does not work when plugging in any other peripherals such as a USB mouse. This computer model only has a single USB-C (or any other port) so it causes a lot of disruption. <br /><br />I have tried turning on and off, cleaning the port and have reset the SMC without any luck.  Any ideas on how to fix it?</p>
<p>⟐ Commented 8月 24, 2023 at 15:02 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/809798/My+USB-C+connector+charges+but+does+not+work+when+using+a+pheripherial</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/809798</guid>
<pubDate>Thu, 24 Aug 2023 15:02:58 -0700</pubDate>
</item>
<item>
<title><![CDATA[Retina MacBook 2017: Nothing happened and my Mac screen is glitchy. Please help!]]></title>
<description><![CDATA[<p>I came home from work one day and opened my MacBook 2017 12in to very glitchy horizontal lines all over the screen. It’s not a physical crack or anything, it seems to follow my mouse and images on the screens. So the lines do move around based on what’s on screen. I have tried restarting it, factory reset, reset nvram, reset smc, updated it to newest version, and ran a maintenance script with nothing showing up. No one touched it, I’ve never dropped it, the only thing that happened to it was my friend who gave it to me spilled something on it like three years ago but the only problems that arose from that were some keys that were jammed. They are easily unjammed though so I really don’t think that has any bearing on it. Whyyyyyy? I don’t understand. Please help!!!</p>
<p>⟐ Answered 1月 20, 2023 at 13:27 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/765261/Nothing+happened+and+my+Mac+screen+is+glitchy.+Please+help!</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/765261</guid>
<pubDate>Fri, 20 Jan 2023 13:27:46 -0700</pubDate>
</item>
<item>
<title><![CDATA[Retina MacBook 2017: MacBook has not been charging and is shut down]]></title>
<description><![CDATA[<p>My MacBook has not been charging with a USB-C cable. I have tried multiple cords but none have worked, it is a problem with the computer itself. I looked into the charging port and there is no debris. It is out of battery so I cannot turn it on, I am not sure how to fix this.</p>
<p>Thank you!</p>
<p>⟐ Commented 10月 03, 2022 at 11:46 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/535169/MacBook+has+not+been+charging+and+is+shut+down</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/535169</guid>
<pubDate>Mon, 03 Oct 2022 11:46:33 -0700</pubDate>
</item>
<item>
<title><![CDATA[Retina MacBook 2017: MacBook Air 2018 Keyboard Backlight Issues]]></title>
<description><![CDATA[<p>I have a 2018 Macbook Air Retina. The problem with my mac is when I restart the PC and on the Login screen where I will enter my password, The keyboard backlight will be on and will goes offer after entering password and getting to the main window screen. The backlight wont work again and the settings to adjust the keboard backlight is not available at the keyboard preferences screen. Any help??</p>
<p>⟐ Answered 4月 04, 2022 at 8:06 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/727714/MacBook+Air+2018+Keyboard+Backlight+Issues</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/727714</guid>
<pubDate>Mon, 04 Apr 2022 08:06:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Retina MacBook 2017: Display error - lines on right side]]></title>
<description><![CDATA[<p>Hey guys,</p>
<p>I plan on buying a used MacBook 2017 Retina. The picture shows, that it has a display error on the right hand side. As I will mainly use it with external displays attached, I don’t worry too much about it, but would like to know, if this is a common problem that is easily fixable or a bigger problem that needs a fix from apple?</p>
<p>Thank you all for your help,</p>
<p>Stefan</p>
<p>Hallo Leute,</p>
<p>ich habe vor mir ein gebrauchtes MacBook 2017 Retina zu kaufen. Auf den Bildern sieht man, dass es einen Displayfehler auf der rechten Seite hat. Da ich es hauptsächlich über externe Monitore betreiben werde, stört mich das nicht allzu sehr, aber ich würde gerne wissen, ob dies ein bekanntes, leicht zu behebendes Problem ist, oder aber etwas schwerwiegendes, was eine Reparatur von Apple benötigt.</p>
<p>Danke für eure Hilfe,</p>
<p>Stefan</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/jLSbvCKC3yaDCAoG.standard" width="172" height="225" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/jLSbvCKC3yaDCAoG.huge&quot;, '', 'width=913,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/nnTwY4psAv5R6uAB.standard" width="175" height="225" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/nnTwY4psAv5R6uAB.huge&quot;, '', 'width=930,height=1200')" /></div>
<p>⟐ Commented 2月 07, 2022 at 5:14 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/721049/Display+error+-+lines+on+right+side</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/721049</guid>
<pubDate>Mon, 07 Feb 2022 05:14:52 -0700</pubDate>
</item>
<item>
<title><![CDATA[Retina MacBook 2017: Possibility of Increasing RAM in Apple MacBook 12"]]></title>
<description><![CDATA[<p>I have Apple MacBook 12” laptop of Mid 2017 (A1534 model). I am have 1.3 GHz version of 8GB RAM. Asking if I can now increase the RAM from 8GB to 16GB?</p>
<p>⟐ Answered 2月 01, 2022 at 14:17 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/601100/Possibility+of+Increasing+RAM+in+Apple+MacBook+12%22</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/601100</guid>
<pubDate>Tue, 01 Feb 2022 14:17:16 -0700</pubDate>
</item>
<item>
<title><![CDATA[Retina MacBook 2017: New style liquid indicators]]></title>
<description><![CDATA[<p>Has anyone noticed the indicators are now black rather than white? I’ve heard a rumour they’re now inspected with UV or black light? Can anyone shed any light and maybe even show a triggered and not triggered examples?</p>
<p>⟐ Commented 10月 19, 2020 at 19:27 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/554578/New+style+liquid+indicators</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/554578</guid>
<pubDate>Mon, 19 Oct 2020 19:27:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[Retina MacBook 2017: How to install a system on an erased drive]]></title>
<description><![CDATA[<p>My customer booted from an external drive and used Disk Utility to erase the drive.  So the repair/restore partition is gone.</p>
<p>It boots and runs fine from an external drive but when I try to install a system it tells me it has to be connected to a power source but there is only the one USB c port.</p>
<p>Any ideas on how to get a system on it?</p>
<p>⟐ Answer accepted 4月 18, 2019 at 4:18 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/562272/How+to+install+a+system+on+an+erased+drive</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/562272</guid>
<pubDate>Thu, 18 Apr 2019 04:18:36 -0700</pubDate>
</item>
<item>
<title><![CDATA[Retina MacBook 2017: How to fix vertical white lines on 2017 MacBook screen?]]></title>
<description><![CDATA[<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/GTQmFy6KotUlFc4v.standard" width="169" height="225" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/GTQmFy6KotUlFc4v.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>This is what my computer looks like when I start it up. I unplugged it this morning and then opened my screen up to this. The white lines seem to be heavier wherever there is an application open/app icon on the screen. When I shut down my computer the white lines go away and it goes fully black once again. How do I fix this problem?</p>
<p>⟐ Commented 11月 08, 2020 at 12:24 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/665056/How+to+fix+vertical+white+lines+on+2017+MacBook+screen</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/665056</guid>
<pubDate>Sun, 08 Nov 2020 12:24:05 -0700</pubDate>
</item>
<item>
<title><![CDATA[Retina MacBook 2017: After Battery Replacement: Keyboard, Trackpad, Audio not working]]></title>
<description><![CDATA[<p>​</p>
<p>​​Hello,<br /></p>
<p>I replaced the battery (Battery Model A1705) for my Macbook 12&quot; 2017 (Macbook Model A1534 - EMC 3099). After battery replacement, the trackpad and keyboard and audio no longer work and laptop speed is slower than before replacement and only the power button is working well.<br /></p>
<p>To fix it, I just purchased a replacement for all flat cables such as keyboard and trackpad, LCD, audio, power and replaced all flats cables with care, The Issue not resolved, so I purchased a replacement trackpad and keyboard and replaced them carefully, But the issue is still not resolved.<br /></p>
<p>By research, I found out the reason for the slow speed of the laptop is maybe the CPU on SMC mode and not using all power for safety and protection, As the keyboard is not working, I can not do SMC reset, I just connected the external keyboard and mouse, they are working well, tried to do SMC via external keyboard but it seems not possible or maybe I do not know how to do it exactly.<br /></p>
<p>By the way, with the SMC reset my issue may still remain, So if you have any experience with this issue or if you have any recommendation and solutions please let me know.</p>
<p>Thank you.</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_06_04_Num_2021" class="header">Update (06/04/2021)</h3></div>
<p>Update: Result of Macbook Diagnostics: PFM006 and PPN001</p>
<p>⟐ Answer edited 5月 28, 2023 at 19:57 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/694429/After+Battery+Replacement:+Keyboard,+Trackpad,+Audio+not+working</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/694429</guid>
<pubDate>Sun, 28 May 2023 19:57:18 -0700</pubDate>
</item>
<item>
<title><![CDATA[Retina MacBook 2017: My trackpad and keyboard keep freezing]]></title>
<description><![CDATA[<p>i’ve had this macbook for a few months and just randomly it started off as my screen mouse freezing whilst i was using it so i didn’t pay that no mind and i just powered it off and tried to turn it back on but when i then tried to turn it back on my it came back as a black and white picture of a mouse apple mouse and the side of a laptop with the apple website link</p>
<p>and on the link apple was suggesting i buy a separate trackpad to use with my laptop</p>
<p>i’ve tried all the keys and power button hacks that i have found on line and have been successful twice but then after 30 minutes i will go back to having the same issue my laptop works i’m just not sure as to why the keyword and trackpad randomly freeze and doesn’t allow me back inside the laptop</p>
<p>can someone please help me find a solution to my problem?</p>
<p>⟐ Answered 3月 22, 2024 at 0:11 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/812679/My+trackpad+and+keyboard+keep+freezing</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/812679</guid>
<pubDate>Fri, 22 Mar 2024 00:11:26 -0700</pubDate>
</item>
</channel>
</rss>
