<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Home Audio Amplifier&quot;]]></title>
<link>https://jp.ifixit.com/Answers/Device/Home_Audio_Amplifier/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Home Audio Amplifier&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Wed, 12 Aug 2026 04:28:04 -0700</pubDate>
<item>
<title><![CDATA[Home Audio Amplifier: Why won't my Amp power up?]]></title>
<description><![CDATA[<p>I have an A500 Behringer power amp that will not power up. I replaced the power cord and fuse with known working ones, with no result. Next, I took the fuse I tested in it and plugged it back into a working amp of the same model, which ran fine (so I know the amp isn't just killing fuses).</p>
<p>Any ideas?</p>
<div class="clearer"></div><div class="headerContainer"><h2 id="Section_UPDATE" class="header">UPDATE:</h2></div>
<p>(I would have put this as a comment,  but needed more words. I would have edited my original post, but couldn't upload pics on an edit.) Every once in a long while, the lights on the front of the power amp will light briefly and then die, but 98 percent of the time, nothing. I have opened it up, and here is the power path:</p>
<p>There is the plug/fuse combo:</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/ty5vI6p21powNYR5.standard" width="282" height="211" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/ty5vI6p21powNYR5.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>As you can see, there is a green/yellow ground. There is a black wire that goes straight into the heart (massive heavy cylinder of wires) of the amp. There is another black wire with a capacitor (I think?) directly after the plug. This wire goes to the switch in the front, which is a simple push button. There is a blue wire coming out of the switch back into the heart of the amp, completing the circuit.</p>
<p>The rest of the components (led board, input boards, output boards, volume knobs) seem irrelevant because it's not getting power at tall (but I could be wrong). Here's a pic of the entire setup:</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/tq3w6arFUiDjoSJj.standard" width="282" height="211" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/tq3w6arFUiDjoSJj.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>Any ideas? I am not an electrician, so please use small words :)</p>
<p>⟐ Commented 8月 02, 2026 at 19:01 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/2453/Why+won&#039;t+my+Amp+power+up</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/2453</guid>
<pubDate>Sun, 02 Aug 2026 19:01:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: Dixon K2150USB - No power]]></title>
<description><![CDATA[<p>My Dixon K2150USB amplifier will not power on. Upon opening the chassis, I discovered a significant amount of brown, gritty debris across the PCB and clear evidence of a thermal event.</p>
<p>There is also heavy corrosion or debris near the power transistors and surrounding resistors (including a 1W10R resistor).</p>
<p>I need help identifying what caused this failure and what the best approach is for cleaning and repairing the board. Specifically:</p>
<p>What is the likely source of the brown debris (insect nesting, capacitor leak, or just dust)?</p>
<p>How can I identify the burned connector to find a replacement?</p>
<p>What other components should I test that are commonly linked to this type of failure in Dixon amplifiers?</p>
<p>I have a multimeter and am comfortable with basic soldering</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/963653/Dixon+K2150USB+-+No+power</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/963653</guid>
<pubDate>Sun, 12 Jul 2026 14:15:30 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: Powersoft digimod 2000hv PSU repair]]></title>
<description><![CDATA[<p>Hello. I think that PSU on my Digimod 2000hv has died. I started checking the transistors and mosfets and I figured that Q2 (12N60A4D) and another chip responsible for DC voltage are dead. Is there anything else i need to check before replacing them? I will also repalce Q1, which is the same as Q2.</p>
<p>⟐ Commented 4月 29, 2026 at 8:16 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/952629/Powersoft+digimod+2000hv+PSU+repair</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/952629</guid>
<pubDate>Wed, 29 Apr 2026 08:16:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[Frequency Amplifier Marshall Kilburn: Why doesn't produce sound on the speakers]]></title>
<description><![CDATA[<p>My mini amplifier I have 2 years using it and it doesn't provide any sound on the speakers I don't know why course I opened it n checked the power board is fine n the is no sign of blown devices</p>
<p>⟐ Commented 4月 19, 2026 at 6:49 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/933164/Why+doesn&#039;t+produce+sound+on+the+speakers</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/933164</guid>
<pubDate>Sun, 19 Apr 2026 06:49:50 -0700</pubDate>
</item>
<item>
<title><![CDATA[Harman Kardon HK3700: Amplifier not making sound why?]]></title>
<description><![CDATA[<p>Sound not hearing</p>
<p>⟐ Commented 4月 18, 2026 at 7:00 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/950935/Amplifier+not+making+sound+why</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/950935</guid>
<pubDate>Sat, 18 Apr 2026 07:00:21 -0700</pubDate>
</item>
<item>
<title><![CDATA[Kicker CXA300.1: This amplifier are not connected with bluetooth]]></title>
<description><![CDATA[<p>This amplifier are not connected with bluetooth</p>
<p>After damage</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/950650/This+amplifier+are+not+connected+with+bluetooth</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/950650</guid>
<pubDate>Thu, 16 Apr 2026 03:42:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: Why does my bass and volume buttons make scratchy noise and bass go aw]]></title>
<description><![CDATA[<p>buttons not working properly and why does the bass goes suddenly off and volume</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/950644/Why+does+my+bass+and+volume+buttons+make+scratchy+noise+and+bass+go+aw</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/950644</guid>
<pubDate>Thu, 16 Apr 2026 03:17:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[Frequency Amplifier Marshall Kilburn: Why is my amplifier keep turning off]]></title>
<description><![CDATA[<p>My amplifier just keeps turning off when I turn up the volume</p>
<p>⟐ Answered 3月 30, 2026 at 5:33 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/916484/Why+is+my+amplifier+keep+turning+off</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/916484</guid>
<pubDate>Mon, 30 Mar 2026 05:33:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: Why does only one of the two channels work]]></title>
<description><![CDATA[<p>Amplifier only play on one channel</p>
<p>⟐ Commented 2月 26, 2026 at 23:55 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/942379/Why+does+only+one+of+the+two+channels+work</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/942379</guid>
<pubDate>Thu, 26 Feb 2026 23:55:16 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: Audio amplifier has short circuit]]></title>
<description><![CDATA[<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/TmIcd6OIVfrLvrIv.standard" width="169" height="225" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/TmIcd6OIVfrLvrIv.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>Hi,I am repairing an audio power amplifier…I don't see any damaged parts but the light bulb indicates that it has a big short circuit…its peavey cs 2000 power amplifier</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/HAHRISBWnDprZacu.standard" width="169" height="225" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/HAHRISBWnDprZacu.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>pls help</p>
<p>⟐ Commented 2月 25, 2026 at 0:39 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/532395/Audio+amplifier+has+short+circuit</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/532395</guid>
<pubDate>Wed, 25 Feb 2026 00:39:06 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: How to conection of amplifier board 6283]]></title>
<description><![CDATA[<div class="clearer"></div><div class="headerContainer"><h2 id="Section_How_to_conection_of_amplifier_board_Num_6283" class="header">How to conection of amplifier board 6283</h2></div>
<p>⟐ Answer edited 2月 24, 2026 at 8:17 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/942002/How+to+conection+of+amplifier+board+6283</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/942002</guid>
<pubDate>Tue, 24 Feb 2026 08:17:18 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: How to fix a protect display]]></title>
<description><![CDATA[<p>I have a onkyo tx sv424</p>
<p>Gow i can fix it</p>
<p>I have CONNECT  a pair of tower speaker that never used or test BEFORE,</p>
<p>Do you think that speaker  can blow a power transistor  and display now  protect on display</p>
<p>Any ideas</p>
<p>⟐ Answered 2月 01, 2026 at 7:39 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/462347/How+to+fix+a+protect+display</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/462347</guid>
<pubDate>Sun, 01 Feb 2026 07:39:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: Sony TA-V7 amplifer has no right channel output]]></title>
<description><![CDATA[<p>Hello! I picked up a vintage amp that was having intermediate issues with the output on the right channel and now no audio will come out of that channel. I've tried switching the speaker wires and panning the audio all the way right but now no sound will come out at all. Any advice and help is appreciated!</p>
<p>⟐ Answered 1月 25, 2026 at 21:53 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/937733/Sony+TA-V7+amplifer+has+no+right+channel+output</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/937733</guid>
<pubDate>Sun, 25 Jan 2026 21:53:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: Crown Cdi 1000, both ch. signal LED’s jumping, no input audio, no out]]></title>
<description><![CDATA[<p>I have a  Cown CDi 1000 that’s has movement in the signal LEDs on both channels , it bounces from 1 green to two. The problem is that this happens when no signal is being applied and when you do send signal you get no audio nor do the LEDs react. Has anyone had this expierence? This is a dual channel issue, no faults.  Any thought on where I should poke around?  This CDi1000 is a 2009 model, I repaired the power supply, mainly the kick start area, the 48.7k resistors were pretty toasty, who ever had it before me did a number on C196 so that was replaced too.  Could U14 cause this kind of issue?</p>
<p>⟐ Answered 11月 26, 2025 at 21:55 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/601803/Crown+Cdi+1000,+both+ch.+signal+LED%E2%80%99s+jumping,+no+input+audio,+no+out</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/601803</guid>
<pubDate>Wed, 26 Nov 2025 21:55:59 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: XTC Amplifier magnet Wire has been burned,need help]]></title>
<description><![CDATA[<p>My magnet wire have just bust by just putting 8 guage performance power cable on a car battery</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/927973/XTC+Amplifier+magnet+Wire+has+been+burned,need+help</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/927973</guid>
<pubDate>Wed, 26 Nov 2025 04:22:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: Sansui AU-X410R - no bias voltage on either channel. PIC incl.]]></title>
<description><![CDATA[<p>Hi guys,</p>
<p>a little stumped with this one. I picked the amp up for next to nothing from a local charity shop. Fired it up via my dim bulb, and it worked, but only just. The output/volume is extremely low. I measured voltage across the emitter resistors, and I'm getting 0 on all 4 of them.</p>
<p>I have checked the power section, and the main rails, and I'm getting around 45v per rail, so that seems ok, Output transistors appear to be ok, and measure fine.</p>
<p>To complicate matters, I cannot find a service manual/schematic for this amp anywhere.</p>
<p>Any help, pointer, tips, would be much appreciated!</p>
<p>Thanks!!</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/pduWIWGOugQiq5jr.standard" width="282" height="143" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/pduWIWGOugQiq5jr.huge&quot;, '', 'width=1600,height=811')" /></div>]]></description>
<link>https://jp.ifixit.com/Answers/View/922222/Sansui+AU-X410R+-+no+bias+voltage+on+either+channel.+PIC+incl.</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/922222</guid>
<pubDate>Thu, 16 Oct 2025 23:06:36 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: Why is my amp staying in protection mode]]></title>
<description><![CDATA[<p>Protection light stays...fuse is good</p>
<p>⟐ Answered 10月 13, 2025 at 8:50 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/386772/Why+is+my+amp+staying+in+protection+mode</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/386772</guid>
<pubDate>Mon, 13 Oct 2025 08:50:11 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: I have a Sansui 550 Classique amplifier -need help]]></title>
<description><![CDATA[<p>My Sansui 550 Classique amp will not turn on, just humming sound and we have blown multiple fuses.  Now even when replacing the fuse we get nothing.</p>
<p>We’ve checked the speaker wires.  Receiver turns on.  Amp shorts out after a crackle-hum sound.</p>
<p>any advice for repairing this?</p>
<p>⟐ Commented 9月 16, 2025 at 3:48 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/716342/I+have+a+Sansui+550+Classique+amplifier+-need+help</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/716342</guid>
<pubDate>Tue, 16 Sep 2025 03:48:21 -0700</pubDate>
</item>
<item>
<title><![CDATA[TEAC GSA-5300 stereo integrated amplifier: Doesn't want to take out sound when I connect to the speakers]]></title>
<description><![CDATA[<p>Amplifier don't want to take out sound</p>
<p>⟐ Commented 8月 23, 2025 at 9:21 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/913530/Doesn&#039;t+want+to+take+out+sound+when+I+connect+to+the+speakers</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/913530</guid>
<pubDate>Sat, 23 Aug 2025 09:21:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: Adding an external audio input to this excellent boombox]]></title>
<description><![CDATA[<p>The JVC RC-X610 boombox, like a lot of JVC audio equipment, is surprisingly good but it lacks an external audio input.</p>
<p>Even for an experienced electronic engineer the PCB's are undecipherable without a service manual and schematic.</p>
<p>I have found an very expensive copy of the service manual on eBay. Where do these sellers find their manuals I wonder?</p>
<p>Can anybody point me to a repository of JVC service manuals or specifically, one for the JVC RC-X610 ?</p>
<p>⟐ Answer accepted 8月 11, 2025 at 11:17 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/162114/Adding+an+external+audio+input+to+this+excellent+boombox</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/162114</guid>
<pubDate>Mon, 11 Aug 2025 11:17:41 -0700</pubDate>
</item>
</channel>
</rss>
