<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Apple MagSafe2 Power Adapter&quot;]]></title>
<link>https://jp.ifixit.com/Answers/Device/Apple_MagSafe2_Power_Adapter/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Apple MagSafe2 Power Adapter&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sat, 15 Aug 2026 16:15:03 -0700</pubDate>
<item>
<title><![CDATA[Apple MagSafe2 Power Adapter: Is there any known way to test Mag-Safe adapters]]></title>
<description><![CDATA[<p>I’d like to be able to tell if I have a bad Mag-Safe adapter or if I need to look at the computer.  I know they fail, as I have a box full of failed ones.  It would be nice to tell first if my power source is working correctly.  Anybody know how?</p>
<p>You would think there would be some type of testing software.</p>
<p>⟐ Commented 4月 05, 2026 at 18:42 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/532249/Is+there+any+known+way+to+test+Mag-Safe+adapters</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/532249</guid>
<pubDate>Sun, 05 Apr 2026 18:42:11 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple MagSafe2 Power Adapter: What could be the problem if the magsafe charger only b]]></title>
<description><![CDATA[<p>What could be the problem if the MagSafe charger only power when sparks together? I don’t know</p>
<p>⟐ Answer edited 3月 02, 2026 at 8:53 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/942913/What+could+be+the+problem+if+the+magsafe+charger+only+b</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/942913</guid>
<pubDate>Mon, 02 Mar 2026 08:53:14 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple MagSafe2 Power Adapter: Is it possible to seperate this part?]]></title>
<description><![CDATA[<p>The cable housing has split exposing the wire directly above the rubber seal, I need to pull through the cable but it is stuck tight.... is there a way to open this part up, pull though the cable to re-solder it to the chargers board, and then get it back together?</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/Idc1KRys65tqtpZo.standard" width="282" height="211" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/Idc1KRys65tqtpZo.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/Zc2lQPZUKOEoYVtR.full" width="227" height="227" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/Zc2lQPZUKOEoYVtR.full&quot;, '', 'width=227,height=227')" /></div>
<p>⟐ Commented 1月 05, 2026 at 0:21 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/933801/Is+it+possible+to+seperate+this+part</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/933801</guid>
<pubDate>Mon, 05 Jan 2026 00:21:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple MagSafe2 Power Adapter: Dim Orange charging light]]></title>
<description><![CDATA[<p>Original Apple 85w charger, clean like new, no damage or bends on the cable, the Pins on the connector and the charging port are spotless clean but the orange light when charging is quite dim (Green light is bright OK), It is charging the MacBook as per normal and is not getting hot. I tested the MacBook with another charger and it is much brighter (normal). The battery is getting old and will be replaced when the replace now message comes (910 CC 74%). What is possibly causing this? Dying charger?</p>
<p>⟐ Edited by author 10月 05, 2025 at 19:10 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/920566/Dim+Orange+charging+light</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/920566</guid>
<pubDate>Sun, 05 Oct 2025 19:10:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple MagSafe2 Power Adapter: How to disassembly MagSafe 2 T connector to fix pins springs?]]></title>
<description><![CDATA[<p>My MagSafe 2 connecter is heating so much and i found that it cause by pins that stuck a little bit. I wanted to fix it, but couldn't disassembly with pliers. How can i fix it with/without disassembly?</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/SBeCxtQEPxN6Tm4G.standard" width="218" height="225" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/SBeCxtQEPxN6Tm4G.full&quot;, '', 'width=353,height=366')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/4mgnstLECFQPyZGV.standard" width="217" height="225" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/4mgnstLECFQPyZGV.full&quot;, '', 'width=440,height=458')" /></div>
<p>⟐ Answered 9月 22, 2025 at 8:31 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/505470/How+to+disassembly+MagSafe+2+T+connector+to+fix+pins+springs</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/505470</guid>
<pubDate>Mon, 22 Sep 2025 08:31:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple MagSafe2 Power Adapter: Orange Light on, but it is not connected to laptop!]]></title>
<description><![CDATA[<p>This is a weird one, The orange light is ON on the connector but it isn't connected to the laptop.... It still charges the battery and goes Green to Orange when connected, disconnect and it turns to Orange and the light stays on until I turn the power supply off..... and now it seems to functioning normally, switch off, turn on, Orange light yet it is not connected .......what has happened? (MagSafe II 85w) I was testing an old MB Air 11&quot; with it (Yes I know I should really use the 45w charger for the Air).... and now back to normal..... randomly often happening.</p>
<p>⟐ Commented 12月 29, 2024 at 12:28 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/881775/Orange+Light+on,+but+it+is+not+connected+to+laptop!</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/881775</guid>
<pubDate>Sun, 29 Dec 2024 12:28:46 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple MagSafe2 Power Adapter: Overheating to point of emergency shutoff.]]></title>
<description><![CDATA[<p>Alright, I think my charger is starting to finally go after all these years.</p>
<p>I use it for my Early 2015 13&quot; Retina MacBook Pro. The charger itself is the 60W version.</p>
<p>Recently I've noticed it's been shutting itself off often. As in, charge light turns off, and it stops charging the battery.</p>
<p>When it does this, upon noticing I unplug it, the first time I made the mistake of grabbing the charging block, (I have learned to NOT do that now as I gave myself a decent burn) whenever this happens the charging block is horrifically warm.</p>
<p>The first time this happened I had shrugged it off as an isolated event, as my cat had been sitting on it, and well, my cats pretty warm.</p>
<p>Then it happened 2 more times while having nothing covering it.</p>
<p>The most recent incident was about 5 minutes ago, I noticed a slight burnt smell, (I had also noticed this with the other incidents) my charger was still charging, but I unplugged it and briefly tapped the charger with my finger, it was overheating. I had likely noticed it just before it would've shut itself off.</p>
<p>The charger itself is in surprisingly good shape for it's age, (at least externally, I can't see the inside.) Wire is starting to turn yellow in places, and there is a small tear in the coating but the wires are intact.</p>
<p>I have also noticed that ONLY the block gets warm, not the cable.</p>
<p>My computer's battery is not the best, so I 80% I have it plugged in.</p>
<p>The only other charger I have right now is a Apple MagSafe 2 45W one, not entirely sure if using it would have some sort of negative effect though.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/1bTbcnWSwmfGpLxQ.standard" width="117" height="225" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/1bTbcnWSwmfGpLxQ.full&quot;, '', 'width=512,height=988')" /></div>
<p>Battery temp showed as 31c before being plugged in, so it actually dropped a bit.</p>
<p>⟐ Commented 10月 27, 2024 at 23:45 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/875151/Overheating+to+point+of+emergency+shutoff.</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/875151</guid>
<pubDate>Sun, 27 Oct 2024 23:45:01 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple MagSafe2 Power Adapter: Magsafe 2 fuse location]]></title>
<description><![CDATA[<p>Anyone know of the fuse location in this adaptor (not the Magsafe 1 model)?</p>
<p>thank you</p>
<p>⟐ Commented 7月 24, 2024 at 9:57 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/689046/Magsafe+2+fuse+location</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/689046</guid>
<pubDate>Wed, 24 Jul 2024 09:57:20 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple MagSafe2 Power Adapter: Check if work with multimeter]]></title>
<description><![CDATA[<p>Hi everyone,<br /><br />I have x3 MagSafe 2 - 85W adaptors which I want to sell but I want to be sure they are fully working. I sold my old MacBook and non of my friends have MagSafe compatible Mac so can't check it direct way. I have multimeter at home.<br /><br />How can I check this charger with multimeter to know if its work or not?<br /></p>
<p>Would appreciate your help</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_12_09_Num_2022" class="header">Update (12/09/2022)</h3></div>
<p><a class="user-mention-link notranslate" href="/User/4141278/Geir+Ove+Andersen">@geirandersen</a> I set a multimeter at the setting (see pic) and the it showed 3.1</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/KYbZsGlCRNXSSypN.standard" width="169" height="225" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/KYbZsGlCRNXSSypN.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>⟐ Commented 4月 18, 2024 at 8:11 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/758549/Check+if+work+with+multimeter</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/758549</guid>
<pubDate>Thu, 18 Apr 2024 08:11:59 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple MagSafe2 Power Adapter: Is there a known Mag-Safe II to Mag-Safe III adapter available yet]]></title>
<description><![CDATA[<p>I’m working on a new 14” M1 MacBook Pro and was so glad to see the return of the Mag-Safe adapter but it is an updated version of the Mag-Safe II only a little longer and slimmer.  I am looking for an an adapter to use on the Mag-Safe II to convert it to a Mag-Safe III but have been unable to locate one yet.  Are the any alternatives?</p>
<p>⟐ Answered 3月 26, 2024 at 12:09 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/710848/Is+there+a+known+Mag-Safe+II+to+Mag-Safe+III+adapter+available+yet</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/710848</guid>
<pubDate>Tue, 26 Mar 2024 12:09:25 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple MagSafe2 Power Adapter: Brand new Magsafe2 charger LED light leaking from cable, is it faulty?]]></title>
<description><![CDATA[<p>This a brand new adapter from Apple store, there's a green light leakage from the cable at the magsafe 2 head, is this normal or it's faulty?</p>
<p>It's from UAE apple store and a friend got me the adapter sealed to Egypt so I can't go to apple store right away and replace it unless the friend take it again to UAE.</p>
<p>Sorry for being paranoid, I had terrible stories with repair shops in Egypt which ruined and burnt my previous adapter.</p>
<p>P.S. why not buying from Egypt? No apple stores and it costs 3x its price. I added the Other picture because someone told me on other forum it's scratched not brand new while it was only a residue from the plastic wrap! So it's the same but with flash and the leak is barely visible.</p>
<p>Thank you<br /></p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/MON4TTfcZIBe1QUH.standard" width="282" height="124" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/MON4TTfcZIBe1QUH.huge&quot;, '', 'width=1600,height=704')" /></div>
<p><br /></p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/PdEwMbmP5VGPkl3n.standard" width="282" height="205" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/PdEwMbmP5VGPkl3n.huge&quot;, '', 'width=1600,height=1165')" /></div>
<p><br /></p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/skIBTpXxIOVQLcIn.standard" width="282" height="201" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/skIBTpXxIOVQLcIn.huge&quot;, '', 'width=1600,height=1138')" /></div>
<p><br /></p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/k63g6kAaEQ1G2yCs.standard" width="282" height="151" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/k63g6kAaEQ1G2yCs.full&quot;, '', 'width=1170,height=627')" /></div>
<p>⟐ Commented 2月 06, 2024 at 18:55 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/835557/Brand+new+Magsafe2+charger+LED+light+leaking+from+cable,+is+it+faulty</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/835557</guid>
<pubDate>Tue, 06 Feb 2024 18:55:36 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple MagSafe2 Power Adapter: Cannot unsolder MagSafe2 cable]]></title>
<description><![CDATA[<p>Our rabbit chewed the cable from the MagSafe2, and as I have previously replaced one I thought &quot;oh, well&quot;.</p>
<p>Not so fast. When I put my soldering iron to the points to remove the old cable, the solder does not melt even when the temperature is turned up to max and the board gets discoloured.</p>
<p>Any clue what to do? I could splice the cables of course, bit of a cludge.</p>
<p>Edit: this is a replacement charger, smaller than the original one.</p>
<p>⟐ Commented 10月 01, 2023 at 7:28 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/816787/Cannot+unsolder+MagSafe2+cable</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/816787</guid>
<pubDate>Sun, 01 Oct 2023 07:28:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple MagSafe2 Power Adapter: 2.43V load voltage with magsafe 2]]></title>
<description><![CDATA[<p>Hi,<br />My magsafe2 has a 3v no-load voltage and 2.43v when I connect a 40kohm resistor.</p>
<p>It's tested both at the cable end and inside the box where the cable is soldered.<br />Any common problems that can cause it? Schematics that can assist to trace the problem?</p>
<p>Thanks!</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/806042/2.43V+load+voltage+with+magsafe+2</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/806042</guid>
<pubDate>Tue, 08 Aug 2023 09:43:21 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple MagSafe2 Power Adapter: Why my magsafe 2 light suddenly goes off]]></title>
<description><![CDATA[<p>Been a while ago, my all electrical devices burnt because power surge that I lived, fortunately I repaired all devices except magsafe 2 45 watt, I replaced all broken power components of magsafe 2 (capacitor, varistor, fuse and inductor) then I connected 39k ohm resistor to output pins (0.6v without connecting 39k ohm) and I saw 15v on output, It worked technically and charged my MacBook as well but sometimes light turns off suddenly and charging stops, after unplugging cable and plugging it again, It starts charging again but not for long, I can't estimate what's wrong with it, thanks in advance.</p>
<p>⟐ Commented 12月 26, 2022 at 14:52 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/691725/Why+my+magsafe+2+light+suddenly+goes+off</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/691725</guid>
<pubDate>Mon, 26 Dec 2022 14:52:28 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple MagSafe2 Power Adapter: Hack magsafe 2 to use as generic PSU]]></title>
<description><![CDATA[<p>Hi,</p>
<p>I. have an 85W Magsafe 2, which had the cable damaged.</p>
<p>As I don’t need it to power a mac, would it be possible to use it as a bench power supply?</p>
<p>Measuring the voltage with no load, shows 3V on my multimeter. How can I make it work? I read somewhere that it needs to see 40kohm, to activate.</p>
<p>I’ve tried to put a 40kohm resistor there and it doesn’t wake up to max voltage.</p>
<p>Cheers,</p>
<p>Pedro</p>
<p>⟐ Commented 9月 18, 2022 at 4:31 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/709002/Hack+magsafe+2+to+use+as+generic+PSU</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/709002</guid>
<pubDate>Sun, 18 Sep 2022 04:31:52 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple MagSafe2 Power Adapter: Why is this MagSafe2 cable turning yellow?]]></title>
<description><![CDATA[<p>A teacher from my high school came to me with her MagSafe2 charger for her MacBook Air and asked me why it is yellowing. Is this dangerous to the point where I should give her a new one or is it just grime/dirt. If it is grime/dirt how would I go about cleaning it?</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/hawlGCSWLWmbnfZO.standard" width="169" height="225" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/hawlGCSWLWmbnfZO.huge&quot;, '', 'width=901,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/qM6O2UvZBLsYWyoh.standard" width="169" height="225" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/qM6O2UvZBLsYWyoh.huge&quot;, '', 'width=901,height=1200')" /></div>
<p>⟐ Answer deleted 9月 29, 2021 at 7:51 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/523046/Why+is+this+MagSafe2+cable+turning+yellow</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/523046</guid>
<pubDate>Wed, 29 Sep 2021 07:51:49 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple MagSafe2 Power Adapter: Problem with MagSafe2 Power Adapter after replacing the cable]]></title>
<description><![CDATA[<p>Hello<br /><br />I replaced the cable - MagSafe 2 (the old one was cut). After that i have a problem with charging. I have to plug the cable into the socket on the computer several times until it starts working. When I do that I can disconnect and reconnect and its ok but.. when I unplug the cord from the wall socket it not working again (charger reset?) ..<br /><br />I have already try with 3 new cables (original) and problem is the same. When I use my old one its fine..</p>
<p>Do you have any ideas?</p>
<p>⟐ Answer accepted 9月 01, 2021 at 13:04 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/704043/Problem+with+MagSafe2+Power+Adapter+after+replacing+the+cable</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/704043</guid>
<pubDate>Wed, 01 Sep 2021 13:04:53 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple MagSafe2 Power Adapter: Magsafe 2 85W charger will not charge 2015 MacBook Pro]]></title>
<description><![CDATA[<p>I have an old 85W Magsafe 1 charger with a T-tip (yes, it’s an odd ball one) that I converted to a Magsafe 2 T-tip by resoldering a brand new Magsafe 2 T-tip cable. It charges all all of my laptops without issues:</p>
<ul><li>2013 13” MBP Pro</li><li>2014 15.5” MBP Pro</li><li>2015 13” MBP Air</li></ul>
<p>They all show light up solid green when charged up or solid amber when charging.</p>
<p>Unfortunately, the charger won’t power up my 2015 13” MBP which has the battery disconnected. The amber light on the cable blinks and then turns off.  My other magsafe 2 chargers will at least power it up with a solid amber light. As a test, I tried at least three different chargers and they were able to power it up without issue.</p>
<p>I highly doubt I botched my conversion. Are there other differences either in the MBP 2015 Pro circuitry or the Magsafe 1 circuitry that may cause it not to charge.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/ktNxfJFErpUaBpkZ.standard" width="282" height="211" class="hasMenu hasLarge" alt="画像" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/ktNxfJFErpUaBpkZ.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>⟐ Answer edited 8月 04, 2021 at 9:35 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/701272/Magsafe+2+85W+charger+will+not+charge+2015+MacBook+Pro</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/701272</guid>
<pubDate>Wed, 04 Aug 2021 09:35:19 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple MagSafe2 Power Adapter: 2-Prong Pin loose, causing intermittent connections]]></title>
<description><![CDATA[<p>One of the prongs for my charger is loose and it’s causing the charging connection the cut in and out. The cable is in great condition and my port has nothing stuck in it, so I know it’s likely not those.</p>
<p>I have attached a video showing the loose prong. It requires me to plug in A/C cable very carefully, as fully inserting it disconnects the power. The issue occurs whether I use the duckhead adapter, Apple extension cord, or any 2-prong power cord</p>
<p>is this easily fixable? I would hate to just throw this away</p>
<div class="large videoFrame videoBox_center" style="width:452px"><div class="videoBox"><video id="1nMgVYGZ4oKAvoAa" controls width="448"   height="252"   poster="https://guide-images.cdn.ifixit.com/igi/trDPcvA4lCUlxXOk.large" loop   >  <source src="https://documents.cdn.ifixit.com/igo/video/ifixit/1nMgVYGZ4oKAvoAa_MP4_720.mp4" type='video/mp4; codecs="avc1.4D4029, mp4a.40.2"' res="720" label="480p" /> </video></div></div>
<p>⟐ Answered 5月 02, 2021 at 15:30 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/690699/2-Prong+Pin+loose,+causing+intermittent+connections</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/690699</guid>
<pubDate>Sun, 02 May 2021 15:30:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[Apple MagSafe2 Power Adapter: MagSafe 2 45w Not working after high voltage fault]]></title>
<description><![CDATA[<p>My charger is not working after a high voltage fault occur in my locality. At the time of fault my charge was at ideal position I.e. was not using at that moment for charging, my charger was plugged in board and switch was on but was not using it to charge, after electricity retained back my charger was not working. In fact almost all charger of my home gone. So what are possible damaged comments in my MagSafe 2 45w charger</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/662364/MagSafe+2+45w+Not+working+after+high+voltage+fault</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/662364</guid>
<pubDate>Wed, 21 Oct 2020 23:05:15 -0700</pubDate>
</item>
</channel>
</rss>
