<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Air Compressor&quot;]]></title>
<link>https://jp.ifixit.com/Answers/Device/Air_Compressor?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Air Compressor&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Fri, 24 Jul 2026 00:01:13 -0700</pubDate>
<item>
<title><![CDATA[Black and Decker Air Station: Pump needs a new valve.]]></title>
<description><![CDATA[<p>I have a very old Black &amp; Decker Air Station. It's an electric air pump great for pumping up car tires etc. So despite being probably 20 years old, it still works great, with one catch. Like most pump valves, when you flip the lever back, it squishes a piece of rubber that squeezes the valve of the tube/wheel, which creates the seal. Well after 20 years, the rubber in my valve is completely dry-rotted. If I could get a new valve, this old pump would be as good as new. But as it stands now, you can't use the pump because all the air the pump tries to put in the tube, just escapes out of the pump's poor seal around the tube's valve.</p>
<p>Some pictures:</p>
<p><a href="http://img825.imageshack.us/img825/1787/img0076o.jpg" rel="nofollow noopener noreferrer">Pic 1</a></p>
<p><a href="http://img20.imageshack.us/img20/3170/img0078fj.jpg" rel="nofollow noopener noreferrer">Pic 2</a></p>
<p><a href="http://img691.imageshack.us/img691/5600/img0077bah.jpg" rel="nofollow noopener noreferrer">Pic 3</a></p>
<p>⟐ Commented 9月 22, 2022 at 0:16 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/48408/Pump+needs+a+new+valve.</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/48408</guid>
<pubDate>Thu, 22 Sep 2022 00:16:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[Campbell Hausfeld FP204800: Why is my compressor outputting water?]]></title>
<description><![CDATA[<p>When using my compressor, sometimes small amounts of water come out along with air.</p>
<p>⟐ Answer accepted 8月 03, 2016 at 7:08 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/199290/Why+is+my+compressor+outputting+water</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/199290</guid>
<pubDate>Wed, 03 Aug 2016 07:08:11 -0700</pubDate>
</item>
<item>
<title><![CDATA[Campbell Hausfeld FP204800: Why does my compressor take so long to get up to maximum pressure?]]></title>
<description><![CDATA[<p>It takes several minutes, more than 20, to get up to maximum pressure. Also after a couple of cycles the compressor won’t start again.</p>
<p>⟐ Commented 12月 08, 2022 at 16:28 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/526480/Why+does+my+compressor+take+so+long+to+get+up+to+maximum+pressure</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/526480</guid>
<pubDate>Thu, 08 Dec 2022 16:28:15 -0700</pubDate>
</item>
<item>
<title><![CDATA[Airpress LM 50-350: Motor failure, motor components breakdown]]></title>
<description><![CDATA[<p>There is an induction or ac motor that is burned out, the plan is restore the ac motor</p>
<p>⟐ Answered 12月 01, 2023 at 2:06 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/826447/Motor+failure,+motor+components+breakdown</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/826447</guid>
<pubDate>Fri, 01 Dec 2023 02:06:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[Husky Air Compressor H2G3TK  2009 2009: Compressor doesn't start?]]></title>
<description><![CDATA[<p>Give the replacement motor part number which isn't listed. But the motor is shown. <strong>Thanks 👍 😊</strong></p>
<p>⟐ Commented 5月 02, 2026 at 18:28 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/931143/Compressor+doesn&#039;t+start</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/931143</guid>
<pubDate>Sat, 02 May 2026 18:28:54 -0700</pubDate>
</item>
<item>
<title><![CDATA[MiTM Air Compressors AM1HE0205HD 2014: Tough to get going. Blows fuse a couple seconds after turning on]]></title>
<description><![CDATA[<p>Takes multiple ( 15-20) tries to fully Start and build pressure. With tank at 0 psi flip switch to run and it starts turning over slowly then pops the fuse. Wait for fuse to reset and turn on and same thing slowly turns over then blows fuse. This continues over and over till it warms up???? And finally stays on and builds pressure. What do you think it could be? Capacitors??? Head gasket?? Any suggestions would be appreciated.  After it gets going it runs and restarts fine</p>
<p>⟐ Answered 11月 04, 2025 at 10:22 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/762194/Tough+to+get+going.+Blows+fuse+a+couple+seconds+after+turning+on</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/762194</guid>
<pubDate>Tue, 04 Nov 2025 10:22:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[Porter Cable Air Compressor C2002  TYPE 5: Good motor, not much air]]></title>
<description><![CDATA[<p>.Motor runs but will not get over 20 psi</p>
<p>Could  o-rings be deteriorating?</p>
<p>⟐ Answered 10月 13, 2024 at 0:11 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/872862/Good+motor,+not+much+air</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/872862</guid>
<pubDate>Sun, 13 Oct 2024 00:11:23 -0700</pubDate>
</item>
<item>
<title><![CDATA[Air Compressor: Why is my Kaiser air compressor power cable overheating]]></title>
<description><![CDATA[<p>Hello All,</p>
<p>Please i need a help</p>
<p>I have a Kaiser air compressor which is over heating the power cable</p>
<p>I did a continuity test at the power terminals on the compressor it read:</p>
<p>*Red-Yellow phase read Open(No  continuity)</p>
<p>*Yellow-Blue phase read Continuity</p>
<p>Please with the above readings can determine if the compressor good or bad???Hello All, Please i need a help I have a Kaiser air compressor which is over heating the power cable I did a continuity test at the power terminals on the compressor it read:  Red-Yellow read Open(No  continuity) Yellow-Blue read Continuity</p>
<p>With the above readings can determine if the compressor good or bad???</p>
<p>⟐ Commented 2月 13, 2024 at 13:08 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/836504/Why+is+my+Kaiser+air+compressor+power+cable+overheating</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/836504</guid>
<pubDate>Tue, 13 Feb 2024 13:08:17 -0700</pubDate>
</item>
<item>
<title><![CDATA[Campbell Hausfeld Air Compressor: extremely slow to build pressure]]></title>
<description><![CDATA[<p>I have a Campbell Hausfield model DC080100  that is extremely slow to build pressure, what is the problem?</p>
<p>⟐ Edited 12月 22, 2025 at 9:42 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/758738/extremely+slow+to+build+pressure</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/758738</guid>
<pubDate>Mon, 22 Dec 2025 09:42:46 -0700</pubDate>
</item>
<item>
<title><![CDATA[Black and Decker Air Station: Air station quit working]]></title>
<description><![CDATA[<p>I a ired up one tire then hooked my air station to another tire but the air station would not come on.I checked all I could check but it still would not come on.What can I do?Did the ac dc switch suddenly go bad?</p>
<p>⟐ Commented 9月 08, 2022 at 3:20 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/298253/Air+station+quit+working</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/298253</guid>
<pubDate>Thu, 08 Sep 2022 03:20:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[Craftsman Air Compressor 91915309 2016: What tool do I need to take the cover apart]]></title>
<description><![CDATA[<p>My compressor won’t build air. I think it’s leaking where the gauges and the pressure regulator connect to the compressor itself. What tool do I need to take the housing apart?</p>
<p>⟐ Commented 11月 06, 2025 at 22:03 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/925065/What+tool+do+I+need+to+take+the+cover+apart</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/925065</guid>
<pubDate>Thu, 06 Nov 2025 22:03:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Craftsman Air Compressor 92115215 2012: craftsman model 921 152150 pancake air compressor]]></title>
<description><![CDATA[<p>how do i remove the power switch?</p>
<p>⟐ Commented 2月 19, 2026 at 17:48 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/925235/craftsman+model+921+152150+pancake+air+compressor</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/925235</guid>
<pubDate>Thu, 19 Feb 2026 17:48:39 -0700</pubDate>
</item>
<item>
<title><![CDATA[Black and Decker Air Station: pump appears to work, but does not generate any pressure,]]></title>
<description><![CDATA[<p>Motor runs does seem to generate air, but no pressure.  Is it worth repairing? How much?</p>
<p>⟐ Answered 1月 11, 2025 at 15:47 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/853241/pump+appears+to+work,+but+does+not+generate+any+pressure,</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/853241</guid>
<pubDate>Sat, 11 Jan 2025 15:47:20 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dewalt Air Compressors DWFP55126 2016: My unit will not build up pressure pass 30 psi]]></title>
<description><![CDATA[<p>No pressure build up passed 30 psi</p>
<p>⟐ Answered 1月 11, 2025 at 13:38 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/883330/My+unit+will+not+build+up+pressure+pass+30+psi</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/883330</guid>
<pubDate>Sat, 11 Jan 2025 13:38:23 -0700</pubDate>
</item>
<item>
<title><![CDATA[Husky Air Compressor TA2530B  BLACK 2011: Where is the unloader valve for this?]]></title>
<description><![CDATA[<p>I have this air compressor, when their is air in the tank the motor will stall.  Sounds like the unloader valve.  But the diagram does not list anything as an unloader valve.  Is this valve part of another assembly?</p>
<p>⟐ Answer edited 10月 31, 2024 at 18:47 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/875649/Where+is+the+unloader+valve+for+this</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/875649</guid>
<pubDate>Thu, 31 Oct 2024 18:47:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[Air Compressor: Open Amp Sensor error in GD compressor]]></title>
<description><![CDATA[<p>Hi<br /><br />I am working on Gardner Denver Compressor model Electra Saver.<br />I recently came across an error message Shutdown 'Open Amp Sensor'</p>
<p><br />This error message popped up within few minutes upon turning on. There is a light on the Compressor motor as seen in above pic, don't know what it means. The motor doesn't get hot.<br /></p>
<p>After pressing Reset &amp; then Constant run, the compressor runs, in most of the cases - all day. But sometimes it stops after running for few hours with above error message.<br /></p>
<p>I tried to look thru the manual but couldn't find above Error message.<br />Any thoughts what this error is for &amp; how to fix it?<br /><br />Thanks</p>
<p>⟐ Commented 5月 06, 2026 at 21:33 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/946941/Open+Amp+Sensor+error+in+GD+compressor</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/946941</guid>
<pubDate>Wed, 06 May 2026 21:33:15 -0700</pubDate>
</item>
<item>
<title><![CDATA[Husky Air Compressor H2G3TK  2009 2009: Where can I get reed valve replacement]]></title>
<description><![CDATA[<p>Reed valve replacement</p>
<p>⟐ Answered 5月 02, 2026 at 18:29 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/953153/Where+can+I+get+reed+valve+replacement</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/953153</guid>
<pubDate>Sat, 02 May 2026 18:29:57 -0700</pubDate>
</item>
<item>
<title><![CDATA[Porter Cable Air Compressor C2002  TYPE 9 2014: Part #for the pressure switch]]></title>
<description><![CDATA[<p>Part number for pressure switch</p>
<p>⟐ Answered 5月 02, 2026 at 17:48 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/953179/Part+%23for+the+pressure+switch</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/953179</guid>
<pubDate>Sat, 02 May 2026 17:48:34 -0700</pubDate>
</item>
<item>
<title><![CDATA[Hitachi Air Compressor EC510 2012: My compressor will not gain more than 45 psi and keeps running.]]></title>
<description><![CDATA[<p>My compressor will not gain more than 45 psi and keeps running Any thoughts</p>
<p>⟐ Commented 4月 30, 2026 at 17:49 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/952626/My+compressor+will+not+gain+more+than+45+psi+and+keeps+running.</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/952626</guid>
<pubDate>Thu, 30 Apr 2026 17:49:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[Husky Air Compressor 0300813A 2017: How do I order replacement off on switch number 17 on diagram]]></title>
<description><![CDATA[<p>Need replacement parts</p>
<p>⟐ Answered 4月 28, 2026 at 19:05 GMT-7</p>]]></description>
<link>https://jp.ifixit.com/Answers/View/952560/How+do+I+order+replacement+off+on+switch+number+17+on+diagram</link>
<guid isPermaLink="false" >https://jp.ifixit.com/Answers/View/952560</guid>
<pubDate>Tue, 28 Apr 2026 19:05:59 -0700</pubDate>
</item>
</channel>
</rss>
