メインコンテンツにスキップ
Nintendo Wii U DVD Drive Replacement
必要な工具と部品
  1. Nintendo Wii U DVD Drive Replacement, Console Outer Case: 手順 1、 1の画像 1
    • With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
    • Three 5.1mm Phillips #000 screws
    • Two 6.1mm Tri-wing Y0 screws
    • One 13.2mm Tri-wing Y1 screw
  2. Nintendo Wii U DVD Drive Replacement: 手順 2、 1の画像 1
    • Rotate the console 180 degrees so that the exhaust vents are facing you.
    • Remove the two 7.1mm Phillips #00 screws.
  3. Nintendo Wii U DVD Drive Replacement: 手順 3、 2の画像 1 Nintendo Wii U DVD Drive Replacement: 手順 3、 2の画像 2
    • On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
  4. Nintendo Wii U DVD Drive Replacement: 手順 4、 1の画像 1
    • On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
  5. Nintendo Wii U DVD Drive Replacement: 手順 5、 3の画像 1 Nintendo Wii U DVD Drive Replacement: 手順 5、 3の画像 2 Nintendo Wii U DVD Drive Replacement: 手順 5、 3の画像 3
    • On the back of the console, lift up and release the main top cover.
  6. Nintendo Wii U DVD Drive Replacement, Front Faceplate: 手順 6、 2の画像 1 Nintendo Wii U DVD Drive Replacement, Front Faceplate: 手順 6、 2の画像 2
    • Rotate the device so that the front plate is facing you.
    • On each side of the console, remove the 3.5mm Phillips #0 screw connecting the DVD drive to the faceplate.
  7. Nintendo Wii U DVD Drive Replacement: 手順 7、 1の画像 1
    • Rotate the device so that the front plate is on the right side and the ribbon cable is visible.
    • The ribbon cable is connected to the system by a latch which holds in the blue tab. Flip this latch up to unlock it.
    • Lift up on the blue tab to release the ribbon cable.
  8. Nintendo Wii U DVD Drive Replacement: 手順 8、 1の画像 1
    • Remove the front faceplate.
  9. Nintendo Wii U DVD Drive Replacement, DVD Drive: 手順 9、 1の画像 1
    • On each side of the DVD drive, remove the two 4.6mm Phillips #0 mounting screws.
  10. Nintendo Wii U DVD Drive Replacement: 手順 10、 2の画像 1 Nintendo Wii U DVD Drive Replacement: 手順 10、 2の画像 2
    • Rotate the device so that the disc drive slot is visible.
    • A ribbon cable is attached to the bottom right side of the disc drive. The ribbon cable can rip if it isn't removed properly.
    • Lift the disc drive out of the mount and turn over to the right so it lies like a book.
    • Use a spudger to release the ribbon cable.
  11. Nintendo Wii U DVD Drive Replacement: 手順 11、 1の画像 1
    • Remove the disc drive.
終わりに
52 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Kim Arre
メンバー登録日: 01/11/13
4,918 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 17-20, Forte Winter 2013 Cal Poly, Team 17-20, Forte Winter 2013人のメンバー
CPSU-FORTE-W13S17G20
5 メンバー
39のガイドは作成済み
48 件のコメント
I've done with twice with two different drives ordered on Ebay, and keep getting the same error code (160-1402). Is the place I'm buying from selling bad drives, or is there something else that needs to be done after? It goes back to working when I put my old one back in, so I know I'm physically doing it correctly.
Brad Senatore - 返信
Update : For anybody else having this problem, you have to change out the logic board from your old drive to the new one. Pain in the neck, but works!
Brad Senatore -
What do you mean by change out the logic board?
gingindua -
the logic board is inside the disk drive. Remove it and replace it into the new disk drive. This is the same on the Xbox and Playstation
rehrnsberger -
Did an update it failed rebooted and now get a 160-1402. With the DVD drive cover off the Spindle isnt moving. Suspect Drive would seem 160-XXXX is DVD Drive related Errors
Ben Uwins - 返信
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 102
過去 30 日: 541
今までの合計 78,927
