メインコンテンツにスキップ
New Nintendo 3DS Cover Plate Replacement
必要な工具と部品
  1. New Nintendo 3DS Cover Plate Replacement, Placing the system on a flat table.: 手順 1、 1の画像 1
    • Ensure your device is powered off before proceeding. Failure to do so may result in electrical shock or damage to the device.
    • Place the system on a flat stable surface.
    • The Cover Plates will ONLY work with the New Nintendo 3DS. They are not compatible with New Nintendo 3DS XL or any other Nintendo system.
  2. New Nintendo 3DS Cover Plate Replacement, Unscrewing the back cover plate.: 手順 2、 1の画像 1
    • Use a size #0 phillips-head screwdriver to loosen the screws from the back cover plate. The screws are attached to the cover, so they will not come out completely.
  3. New Nintendo 3DS Cover Plate Replacement, Prying up the back cover plate.: 手順 3、 1の画像 1
    • Use the nub on the end of the stylus , a fingernail or a plastic opening tool to gently pry on the small slots on each side near the L and R buttons. Once the cover plate begins to separate from the system, gently remove it.
  4. New Nintendo 3DS Cover Plate Replacement, Prying the front cover plate.: 手順 4、 1の画像 1
    • Use the nub on the end of the stylus , a fingernail, or a plastic opening tool to gently pry on the small slots on each side near the L and R buttons. Once the cover plate begins to separate from the system, gently remove it.
  5. New Nintendo 3DS Cover Plate Replacement, Attaching the front cover plate.: 手順 5、 1の画像 1
    • Attach the new front cover plate.
  6. New Nintendo 3DS Cover Plate Replacement, Attaching the back cover plate.: 手順 6、 1の画像 1
    • Attach the new back cover plate and tighten the two #0 phillips-head screws.
終わりに
You have changed the cover plates on your New Nintendo 3DS system.
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
ethan2226
メンバー登録日: 12/26/15
175 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 31
過去 30 日: 218
今までの合計 9,713
