メインコンテンツにスキップ
How to Apply a Screen Protector for iPhone11 Pro Max
必要な工具と部品
  1. How to Apply a Screen Protector for iPhone11 Pro Max, How to Apply a Screen Protector for iPhone11 Pro Max: 手順 1、 2の画像 1 How to Apply a Screen Protector for iPhone11 Pro Max, How to Apply a Screen Protector for iPhone11 Pro Max: 手順 1、 2の画像 2
    • Wipe the dust off the screen with a No. 1 alcohol cleaning wipe.
    • This will help to avoid bubbles when applying the screen protector.
  2. How to Apply a Screen Protector for iPhone11 Pro Max: 手順 2、 1の画像 1
    • Use a dry wipe to wipe off any water stains on the screen.
  3. How to Apply a Screen Protector for iPhone11 Pro Max: 手順 3、 3の画像 1 How to Apply a Screen Protector for iPhone11 Pro Max: 手順 3、 3の画像 2 How to Apply a Screen Protector for iPhone11 Pro Max: 手順 3、 3の画像 3
    • Tear off one of the dust removal tape strips.
    • Use the dust removal tape to clean off the fine dust.
  4. How to Apply a Screen Protector for iPhone11 Pro Max: 手順 4、 3の画像 1 How to Apply a Screen Protector for iPhone11 Pro Max: 手順 4、 3の画像 2 How to Apply a Screen Protector for iPhone11 Pro Max: 手順 4、 3の画像 3
    • Put the auxiliary tool on your phone.
    • Push down so that the auxiliary tool is firmly attached to the phone.
    • This step is not necessary, and it doesn't matter if you don't have it. The auxiliary tool is just to assist you place the screen protector straight.
  5. How to Apply a Screen Protector for iPhone11 Pro Max: 手順 5、 3の画像 1 How to Apply a Screen Protector for iPhone11 Pro Max: 手順 5、 3の画像 2 How to Apply a Screen Protector for iPhone11 Pro Max: 手順 5、 3の画像 3
    • Take out the screen protector. Tear off the release layer of the screen protector (the thinner side).
    • Aim the holes of the screen protector at the holes of the auxiliary tool and then slowly lay the screen protector onto the screen.
  6. How to Apply a Screen Protector for iPhone11 Pro Max: 手順 6、 3の画像 1 How to Apply a Screen Protector for iPhone11 Pro Max: 手順 6、 3の画像 2 How to Apply a Screen Protector for iPhone11 Pro Max: 手順 6、 3の画像 3
    • Wipe the screen surface around with a dry wipe to make the screen protector fit the phone screen better and lay flat.
  7. How to Apply a Screen Protector for iPhone11 Pro Max: 手順 7、 3の画像 1 How to Apply a Screen Protector for iPhone11 Pro Max: 手順 7、 3の画像 2 How to Apply a Screen Protector for iPhone11 Pro Max: 手順 7、 3の画像 3
    • Pull off the the auxiliary tool with your fingers.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Qiyuan Feng
メンバー登録日: 05/10/21
169 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G6, O'Regan Summer 2021 York University, Team S1-G6, O'Regan Summer 2021人のメンバー
YORK-O'REGAN-SU21S1G6
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 7
過去 30 日: 52
今までの合計 1,962
