1の図表
フォーラムで人気の質問
質問する質問はありません。 最初の質問をしてみましょう!
Background and Identification
The Siamons Fogger model 200-620810 is a mold removal fogger that atomizes a mold control solution into a fine mist for even surface application. The mold control solution is meant to eliminate existing mold and prevent mold growth. It is designed for use in musty rooms to eliminate odors and to pre-treat building materials during renovation or construction. The Siamons Mold Removal Fogger can be used for large spaces and hard to reach areas such as wall cavities, basements, crawlspaces, attics, and cellars.
The Siamons Fogger model 200-620810 is designed for use with Concrobium Mold Control liquid. Concrobium recommends removing or covering any room contents that may be damaged if wetted and closing windows and doors to the area. Users can adjust the liquid flow of the fogger head to various rates, but Concrobium recommends a medium flow rate. The fogger’s head angle should be adjusted to ensure even application of the affected area. After fogging, users should allow the fog to dissipate for 15 to 20 minutes and excess wetness should be wiped from surfaces with a clean cloth. Users should allow the surfaces to dry overnight.
The Siamons Fogger model 200-620810 includes an aluminum body with a 128-ounce bucket. Replacement fogger intake filters can be purchased.
Technical Specifications
Brand: Concrobium
Country of Origin: CANADA
Manufacturer Part No: 200-620810
UNSPSC: 60121241
UPC: 897946000603
UPC Code: 897946000603
Container Size: 128 Oz.
Height: 13 inches
