Back Cover
1 件の回答 0 スコア |
Phone stuck in Qualcomm Crashdump Mode |
4件の回答 0 スコア |
I need to clean the speaker holes |
2件の回答 0 スコア |
What is an "LCD Assembly"? |
1 件の回答 2 スコア |
It does not charge or power on. It's completely dead! |
モデル
A6013
Troubleshooting Page
If the OnePlus 6t is having issues, try looking for solutions under the troubleshooting page.
Background and Identification
The OnePlus 6T (model number: A6010) is an Android smartphone released by OnePlus on November 6th, 2018. The model number can be located within the “Unlock The Speed” pamphlet that comes with every new OnePlus phone. Open the pamphlet and look under the “Quick Start Guide" section. The model number should be the last sentence within this grouping of information. The phone was released as a hardware upgrade to the previously released OnePlus 6, and features an improved teardrop camera and an in-display fingerprint scanner, while removing the 3.5 mm audio jack that was featured in the OnePlus 6. The OnePlus 6T was succeeded in May of 2019 by the OnePlus 7.
The device weighs 177g, with gorilla glass 6 on the front screen of the phone and gorilla glass 5 on the back of the phone. It comes with a 6.41-inch AMOLED FHD+ display and a Snapdragon 845 processor, while boasting a larger battery life than the OnePlus 6 with a 3700 mAh battery. There are three cameras on the device: both 16 and 20 megapixel cameras on the back and a 16 megapixel camera on the front screen.
The OnePlus 6T supports 4G, LTE, Dual VoLTE, 3G, 2G, and CDMA.
Technical Specifications
CPU: 64-bit Octa-core (8x Kryo 385 cores, up to 2.8 GHz)
GPU: Adreno 630
RAM: 6 GB or 8 GB LPDDR4X
Storage: 64 GB, 128 GB, or 256 GB configurations
Display
- Size: 6.41 inches
- Resolution: 1080 x 2340 pixels, 19.5:9 ratio, 402 PPI
- Type: Optic AMOLED
- Protection: Corning Gorilla Glass 6
Battery: Non-removable Li-Po 3700 mAh battery
OS: Android 9.0 (Pie)
Camera
- Main Cameras
- 16 Megapixel, f/1.7, OIS
- 20 Megapixel, f/1.7
- 4K resolution video
- Front Camera
- 16 Megapixel, f/2.0
- 1080P resolution video
Connectivity
- Wi-Fi: Wi-Fi 802.11 a/b/g/n/ac, Wi-Fi Direct, DLNA, hotspot, dual-band
- Bluetooth: Bluetooth Low Energy 5.0
- NFC: NFC enabled
- Ports:
- Data & Charging: USB Type-C 1.0
Sensors
- In Dispaly Fingerprint
- Accelerometer
- Gyroscope
- Proximity
Dimensions
- Size: 157.5 x 74.8 x 8.2 mm
- Mass: 6.53 ounces (185g)
