メインコンテンツにスキップ
The Pocophone F1 is a mid-tier smartphone made by Xiaomi Inc, announced on 22 August 2018 in New Delhi, India.
51回答 すべてを表示
Exchanged screen & battery, it worked yesterday, but won't start today
Hi IFixit community,
I hope you can give me some pointers, because this is a mystery.
I exchanged screen and battery of my Pocophone F1 last evening. To confirm that it works I turned it on after a small charging duration. Everything worked fine and the battery showed it was still loading. I shutdown the phone to continue charging.
This morning I am trying to start the phone and it's dead. Aka no reaction to pressing any buttons.
I know that starting the phone directly may have reduced battery time. (Stupid idea.) But, is that the explanation for why the phone is dead? Or could this have something to do with the screen instead? I don't see a way to distinguish between the two defects.
Any ideas? Should I just switch batteries again?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
It seems like you've encountered an issue with your Pocophone F1 after replacing the screen and battery. Here are some troubleshooting steps you can follow to determine the cause and potentially resolve the problem:
1. Check Battery Connection:
- Ensure that the battery connection is secure. Open up the device and reseat the battery connector to make sure it's properly connected to the motherboard.
2. Perform a Hard Reset:
- Sometimes, a hard reset can help in situations like this. Press and hold the power button and volume up button simultaneously for about 10-15 seconds. This should force a restart of the device.
3. Check for Signs of Life:
- Connect the phone to a charger and see if any indicator lights or vibrations occur. If there are no signs of life, it could indicate a battery or power-related issue.
4. Inspect the Screen Connection:
- Ensure that the screen connection is secure and properly seated on the motherboard. Loose connections can cause display or power issues.
5. Try a Different Charger:
- It's possible that the charger you're using isn't providing sufficient power. Try using a different charger and cable to charge the phone.
6. Check for Physical Damage:
- Carefully inspect the phone for any physical damage or signs of a short circuit. Ensure that no components are damaged during the repair process.
7. Use a Known-Good Battery:
- If you have access to a known-good battery, consider swapping the battery to see if it resolves the issue. This can help determine if the problem lies with the battery itself.
8. Seek Professional Repair:
- If the issue persists after trying the above steps, it's advisable to seek professional repair services or contact the manufacturer's support for further assistance.
Remember to take necessary precautions when working with electronic devices, and if you're unsure about any step, it's best to consult with a professional technician or repair service.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
Thanks, I tried all steps. No response. Unless anybody else provides ideas, I will wait for the new battery.
さんによる
@niklassermmler In the meantime, try and clean both the display and battery connectors with isopropyl alcohol, some gunk might be blocking a connection!
さんによる
Nice! I didn't have alcohol, so I used a bare brush. And you know what it worked! Thank you! Make it an answer and I will accept it :).
さんによる
Ah no, there still seems something wrong. The phone suddenly blacks out. Back to square 1. :(
さんによる
コメントを追加
回答を追加する
Niklas Sermmler さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 22
