メインコンテンツにスキップ
Troubleshooting and repair information for the Makita-brand hammer drill with model number HM0870CQ, released in 2014.
1回答 すべてを表示
My Demolition Hammer would turn on but won't hammer
Hi,
My Makita demolition hammer will turn on and the motor will run, but no hammering. I have changed the brushes and it’s still the same outcome. I was thinking of buying a new one, but I thought I’d try my hand at repairing it. I hope you guys can help me out thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
According to the Makita Hammer Drill HM0870CQ instruction manual (available online in pdf), when the brushes are changed, the grease should also be changed. This seems to be a common feature with demolition hammers. Also, if the tool was stored in a cold area, it may have to be run for five or more minutes to warm up the grease enough for the tool to hammer. If the tool ran , there was probably nothing wrong with the brushes; the grease was either cold or depleted. Do an internet search of <Makita Hammer Drill HM0870CQ instruction manual> . This will probably tell you all you need to know.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Oh I see, I will make sure to regrease it when I take it apart. I appreciate it!
さんによる
コメントを追加
Hi @jaimodoode ,
I’ve never worked on an impact drill but here’s the technical information manual for the drill which shows how to disassemble and assemble it.
You may want to check the operation of the impact bolt as this is what creates the hammer action.
Here’s a link that in general explains how the impact system works.
Hopefully between the two of them you will be able to figure it out
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Awesome! Thanks! I will take my time tinkering with it and hopefully get back with positive results.
さんによる
コメントを追加
回答を追加する
Jaim さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 44
過去 30 日: 180
今までの合計 5,104
