メインコンテンツにスキップ
Googleの第三世代Pixelラインのスマートフォンです。初めての”ノッチ付き”スマートフォンです。6.3インチ QHD+ OLEDディスプレイ、64もしくは128GBの容量。Nearly White、Just BlackもしくはNot Pinkのカラーバリエーションがあります。
77回答 すべてを表示
Mic doesn't work after charging port replacement
I replaced my charging port with an iFixit replacement. After putting back together everything works as expected except for the mic when not on speaker phone. From my research, the mic is part of the charging assembly. I am wondering if I received a defective part? I am going to take apart again in check all connections. I’m wondering if anyone else has suggestions…
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
3 件のコメント
Hi. what was the solution for your problem ? have exactly the same problems…..
さんによる
I did another charging port change and the mic works fine now. It's likely the board I received was defective since the connector seemed seated fine for the faulty board. I was able to perform an exchange to receive a new board. After installing the new board, everything works fine now
さんによる
Ok thanks. I think i have the same problem. Ordered new board to test it.
さんによる
コメントを追加
2件の回答
最も参考になった回答
I would imagine it’s defective. Disassemble and check the connection. Sometimes if it’s not seated all the way it won’t work.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I replaced the charging port with a new replacement and the mic now works. I can confirm that the part I used previously was simply defective.
Thanks for the suggestion
さんによる
コメントを追加
Getting another replacement daughter board should fix the problem because some replacement board has faulty mic from factory.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
SEAN BEAUSOLEIL さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 25
今までの合計 621
