Why doesn't my MicroSD work properly?
I inserted my MicroSD card into the slot, but it is not being read.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
First check to see if you are using a MicroSD card that is compatible with your device. If you find that it is compatible, try reformatting the card on the phone using the SD Formatter. If you find your MicroSD isn't compatible with your device try purchasing a new card.
For more help refer to our Troubleshooting Page .
このアンサーは役に立ちましたか?
How do I know if the MicroSD card I'm using is compatible?
You can find your answer here.
Thank you! It finally worked!
過去 24時間: 1
過去 7 日: 2
過去 30 日: 12
今までの合計 135
